B-Block bellhousing #943815
03/06/11 12:41 AM
03/06/11 12:41 AM
WV
bacaruda Offline OP
bacaruda  Offline OP
WV
I had a '64 Polara 4-sp at one time long ago. It had an aluminum bell, and I'm sure a 10.5" clutch. In what I've seen for applications, that doen't exist.
Any help?
Thanks,
Jim.
Re: B-Block bellhousing [Re: bacaruda] #943816
03/06/11 12:44 PM
03/06/11 12:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Any help?
Thanks,
Jim.
What do you want to know ? The alum bell wasn't installed behind a big block till 1970 so no it doesn't have the correct bellhousing BUT the correct was a cast iron that used the 130 tooth wheel (10.5) so you win by saving weight .
