Brake Shoes #943430
03/05/11 02:39 PM
03/05/11 02:39 PM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
i just had to replace my rear brake wheel cylinder due to it was leaking brake fluid all on the inside of my drum, my question is, the whole inside of the brakes and drums was full of brake fluid, i did clean all of the surface fluid off the drums and brakes, will this be fine, i mean the brake shoes were covered in brake fluid, do i need to let them dry out or do i need to replace them?
apparently it has been leaking for some time
thanks
Re: Brake Shoes [Re: cornet684me] #943431
03/05/11 03:00 PM
03/05/11 03:00 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
replace them
It's Swifty! Swifty, you toad sucker!
Re: Brake Shoes [Re: zrxkawboy] #943432
03/05/11 03:04 PM
03/05/11 03:04 PM
Brandon, Ms
Brandon, Ms
so you think with them being soaked in brake fluid ,they will not be good anymore, that is what i was kinda of thinking too, i have not had the car on the road full time yet, only driven it for about 30 miles on the street, however, have been working on it for about 4years and the brakes were the first thing i worked on, apparently i got a bad wheel cylinder, i guess i wld be rather be safe than sorry
thanks for the input
Re: Brake Shoes [Re: cornet684me] #943433
03/05/11 03:09 PM
03/05/11 03:09 PM
Brandon, Ms
Brandon, Ms
anybody else?
Re: Brake Shoes [Re: cornet684me] #943434
03/05/11 04:08 PM
03/05/11 04:08 PM
Brandon, Ms
Brandon, Ms
Re: Brake Shoes [Re: cornet684me] #943435
03/05/11 04:12 PM
03/05/11 04:12 PM
BDW Offline
BDW  Offline
They're not expensive, really no way to get the soaked in fluid out of the shoes.
Replace them.
Re: Brake Shoes [Re: BDW] #943436
03/05/11 04:15 PM
03/05/11 04:15 PM
Brandon, Ms
Brandon, Ms
thanks for the input, guess i am on the way to parts house
Re: Brake Shoes [Re: cornet684me] #943437
03/05/11 05:24 PM
03/05/11 05:24 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Good choice.. As mentioned not terribly expensive & once they get soaked & allowed to stay wet for any length of time they will be grabby after that... If you get them dried off with-in a few minutes they are fine but that isn't the case here...
