Changing oil pan gasket with motor in car...
#941769
03/03/11 12:36 AM
03/03/11 12:36 AM
Posts: 3,344 Central TX
roe
Central TX
How hard is it? I have a 360 in a 71 B body and it looks like I will just have to drop *center link* It looks like its just a matter of me over-tightening the bolts when I didnt have my torque wrench. But now I have one so that shouldnt be a problem. I have the standard cork with rubber end gaskets now, but I think Im going to upgrade to the rubber coated with rubber endgaskets. Do I use any gasket maker with the rubber coated style one (part #1807 @ autozone)? Anything I need to look out for? Any mods I need to make that help it seal better? The leak just started and Ive already crawled under it while its running and verified that its leaking from the front drivers side corner, and want to get it fixed asap. thanks roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
Re: Changing oil pan gasket with motor in car...
[Re: dOOc]
#941777
03/05/11 01:39 PM
03/05/11 01:39 PM
roe
Central TX
does the suspension need to be loaded or unloaded to remove the centerlink
[Re: roe]
#941778
03/05/11 01:45 PM
03/05/11 01:45 PM
Posts: 21,840 Kirkland, Washington
Pacnorthcuda
Can be done either way, I prefer unloaded. ALSO--you will find that if you pop the centerlink off the pitman and idler you can pull it down (because of the tie rods) enough to get pan clearance--You don't have to pop the tie-rods to centerlink. Easier, and preserves your front end toe setting. You'll definately want an unloaded suspension to do this!!!
