F,M,J disc on a b-body ?
#941609
03/02/11 09:07 PM
03/02/11 09:07 PM
Posts: 1,832 Fort Morgan
1OFNONE
Has been a member for quite a few years, so relax.
Fort Morgan
Will this swap work ? or will all the parts work on a b-body spindle ?
So the bartender says to the horse " Gee, Why the long face?"
Re: F,M,J disc on a b-body ? *DELETED*
[Re: rabid scott]
#941611
03/02/11 11:06 PM
03/02/11 11:06 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Post deleted by cjs69mope
1969 Dodge Charger
1969 Dodge Superbee
[Re: feets]
#941616
03/03/11 06:06 PM
03/03/11 06:06 PM
1OFNONE
Fort Morgan
I seem to have hit a hornets nest with a big rock. I have even got some negative p.m.'s from guys about it. I have been a member for quite a few years and people need to relax. This is an information forum not a bunch of hens in a hen house. Good grief. State the facts that you know and leave it at that.
[Re: 1OFNONE]
#941618
03/03/11 06:26 PM
03/03/11 06:26 PM
1OFNONE
Fort Morgan
Whom ever the Mod was that put this "I have been a member for quite a few years and people need to relax" crap on my profile needs to remove it. Its uncalled for !
Mods are to keep the forum clean. Not add fuel to the fire.
[Re: 1OFNONE]
#941621
03/03/11 06:33 PM
03/03/11 06:33 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
I've been running FMJ's on A bodies for a LONG time and NEVER an issue. The B spindles are the same height as the A's in your case. I sell all the A body kits I get and buy 2-3 FMJ set up with the proceeds.
BBD has a nice write up about the geometry with some data, unlike that original article people love to quote. I've never heard of a BJ breaking from over-angling and I believe neither has the author. The change in position is approx or less than 3* at the extremes, IIRC. IMO, there's a bit of CYA journalism in the article which is fine and dandy in our litigious society.
http://www.bigblockdart.com/techpages/spindles.shtml
There lots of dangerous bump steering A and B bodies out there with breaking ball joints. LMAO, so you might want to stay home.
[Re: RobX4406]
#941622
03/03/11 06:35 PM
03/03/11 06:35 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
I've been running FMJ's on A bodies for a LONG time and NEVER an issue. I sell all the A body kits I get and buy 2-3 FMJ set up with the proceeds.
^^^^ What he said...
[Re: Jim_Lusk]
#941625
03/04/11 01:24 AM
03/04/11 01:24 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I put those spindles on my son's 67 Barracuda autocrosser. Never an issue with the suspension on that car.
.....I've been running the F,M,J spindles(prefered) for years, street/strip/roadcourse, no alignment/set up issues, on any of the cars, mine or customers that I've installed them on, including achieving caster requirements,...I do prefer however to change the caliper bracket over to the earlier 70-2 pin style,...IMHO a lot of the "controversy" over the install is by "armchair quarterbacks" calling the plays
Mike
[Re: DAYCLONA]
#941626
03/04/11 04:12 PM
03/04/11 04:12 PM
1OFNONE
Fort Morgan
Thanks everyone for your hard facts as to the issue. Since this is going on a '57 Plymouht, I need to find a '57 Ply spindle and sit it next to a standard disc b-body spindle to check height and angle and such. The quest continues...
[Re: 1OFNONE]
#941627
03/04/11 04:23 PM
03/04/11 04:23 PM
Posts: 25,941 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A '57 isn't a B body that the OP asked about. The F,M,J brakes will work on the Forward Look cars but it's not quite as easy as the B body; some grinding for clearance is required.
[Re: John_Kunkel]
#941628
03/05/11 01:03 PM
03/05/11 01:03 PM
1OFNONE
Fort Morgan
Thanks John. The '57 had FMJ's disc on it when purchased, but had really bad bump steer. So my father took the discs off and put on stock '57 drums and the bump steer went away and now drives like a dream.
In the long run he wants drop spindles on it but they dont make them for drum brakes, disc only.
I believe the arm on the fmj's that bolts on and the tie rod end drops into is the issue.
