Let me say this will it Bolt ON?
YES
Will it work correctly?
NO
Why ?
Because the F,M,J is taller for cars that have rubber frame bushings in between the frame and k frame .
Thus when used with early B-body the upper ball joint is in bind condition and caused Bump Steer .
what is bump steer do a google search for the explanation its not good .
LOL, your wrong on many counts. BTW, the isolators have nothing to do with the spindle height, but if you actually knew anything about the F/M/J front suspension you'd know that.
Don't be the exception.
