SMALL BLOCK PULLEYS AND BRACKETS
#93962
07/24/08 07:01 PM
07/24/08 07:01 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Been a long time since I did a streetable car so help me out with this. Do these pulleys look too close together. They don't touch but they are close. Is this right or do I have the wrong ones? The other ? I have is about the power steering bracket? Is there a difference between A/C and non A/C power steering brackets. This one doesn't seem to line up ![](http://i300.photobucket.com/albums/nn35/wildracing/pulley2.jpg)
Re: SMALL BLOCK PULLEYS AND BRACKETS
[Re: WILD BILL]
#93963
07/24/08 07:13 PM
07/24/08 07:13 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
Your crank and waterpump pulleys are fine but I don't whats up with the P/S bracket- what is it off of? BTW your alternator goes on the other side of the bracket. I've only had a few cars with power steering but haven't had issues with the P/S pump lining up and I always reused the P/S bracket and use the same alt brackets/pulleys you have to ditch the A/C. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: MoparJoe]
#93964
07/24/08 07:22 PM
07/24/08 07:22 PM
WILD BILL
BROOK PARK, OH
The PS bracket is off a 83 small block A/C car. The Alt only fits this way. It's also the way I saw it on others cars
Year one lists a different WP pulley for small and big blocks. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: WILD BILL]
#93966
07/24/08 07:34 PM
07/24/08 07:34 PM
Posts: 15,487 Florida
scratchnfotraction
looks just like what I put on my truck my alt the same way my ps is from the a/c pullys and brackets the ps should line up with the groove closest to the rad alt/wp on the 2nd groove on the crank do you have the 8 blade wp to go with that pulley it turns slower at idle than the a/c pully and 6 blade wp ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: scratchnfotraction]
#93967
07/24/08 07:45 PM
07/24/08 07:45 PM
WILD BILL
BROOK PARK, OH
I have no idea what WP it is. It was a crate motor we bought off another member.
So what PS bracket would be right for this pump in a 72 B body? ![](http://i300.photobucket.com/albums/nn35/wildracing/PSPUMP.jpg)
[Re: RapidRobert]
#93971
07/25/08 08:30 AM
07/25/08 08:30 AM
Posts: 634 Maryland, USA,
satgtx
Maryland, USA,
i would like to see more picks of the power steering pump with the brackets and the spacers for the long mounting bolt.
[Re: stumpy]
#93973
07/25/08 11:12 AM
07/25/08 11:12 AM
WILD BILL
BROOK PARK, OH
I'll have to check that out. The pic was taken at an angle and not dead on so that may make it look worse ![](/ubbthreads/images/graemlins/shruggy.gif)
I can space it out if I need to
