WHICH ROD LENGTH
#938819
02/27/11 07:24 AM
02/27/11 07:24 AM
Posts: 370 Queensland Australia
moparmacka
In an another post I asked about the compression height of a piston for my SB stroker with 4.000" stroke and 6.250" rod. The crank has Chev 2.100" B/E and 340 mains. I have since spoken to the guy I am buying the 6.250" rods from and he said if it easier he will swap them for a 6.125". Apart from the vast off the shelf pistons to suit the 6.125" rod, is there any great advantage (rod ratio etc) in swapping to a 6.250" rod, considering this will not be an all out race engine? I would still have to go a custom piston to obtain the correct comp ratio anyway (aiming for 10.8-11.0 with E/brocks. Most inverted domes are 9.5-10 and flat tops yeild 11.5-12 static comp ratio). Thanks Macka
Re: WHICH ROD LENGTH
[Re: moparmacka]
#938820
02/27/11 07:47 AM
02/27/11 07:47 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
.......is there any great advantage (rod ratio etc) in swapping to a 6.250" rod, considering this will not be an all out race engine?
No. Even in a complete race application, the difference would be negligable. However, since you say a custom piston is required either way, I'd do it. I usually build what I want, when I'm paying for it.
IIRC, Don Gentry(B3422W5) used a 6.250" rod in his 4" engine. I'm sure, it's been done many times. There is no downside to using it in your case.......Cost being the only factor.
[Re: moparmacka]
#938821
02/27/11 08:13 AM
02/27/11 08:13 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I doubt you'll notice any difference with a 2% change in rod length. In most normally asperated engines the preference is to use a longer rod. I think the reasoning is the long rod keeps the piston near TDC (Dwell) for a longer time than a short rod. On the intake stroke this allows the cam to open the intake valve further before the piston reaches maximum velocity. On the compression/ignition stroke it gives the fuel longer to burn with the piston near TDC creating more cylinder pressure. The longer rod would have less angle offset so it should put less side load on the cylinder walls.
[Re: Cab_Burge]
#938823
02/27/11 04:13 PM
02/27/11 04:13 PM
Posts: 1,532 off the grid
340B5
off the grid
A long rod has more of a straight down push@ 90* ATDC. Try peddling a bicycle uphill standing on the peddals vs sitting on the seat. The longer rod will make better mid range torque.
Yeah, it's got a smallblock.
[Re: moparmacka]
#938830
02/28/11 05:55 AM
02/28/11 05:55 AM
S/ST 3040
That piston has a very small dome to offset valve reliefs and yields 13:1 453 grams w/out pin Ring pack is 1/16" x 1/16" x 3/16" Has been running since 2008. Changing rod lengths will have no effect on port velocity. That is determined by port size and engine displacement and RPM.
[Re: 602heavy]
#938831
02/28/11 04:17 PM
02/28/11 04:17 PM
Posts: 4,210 New York
polyspheric
New York
X2: a minimum safe distance for the ring package is step #1, rod length is whatever you have left. Don't try to use the same CD as another engine, the spaces needed differ quite a bit: 1. actual ring thicknesses (1mm vs. 1/16" etc.). 2. crown down-distance for ring #1 (must be greater if nitrous or blown). 3. minimum crown thickness to prevent valve relief from getting too thin at the bottom. This varies with valve size, placement, stem angle and lift. 4. how long is the skirt? If you have 2" of skirt below the pin (assuming it clears the CW and doesn't hang out of the bore 30° B/A BDC), the CD can be even shorter.
Almost any 1.400" is safe. At 1.300", some. At 1.250" you want a .927" (SBC) pin etc. Below that it's not going to last very long.
Boffin Emeritus
[Re: polyspheric]
#938832
02/28/11 05:17 PM
02/28/11 05:17 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
X3: a minimum safe distance for the ring package is step #1, rod length is whatever you have left. Another strong consideration, and maybe ranking first, is off the shelf availability. If you can, get the most components (especially pistons) that you can in case you have a problem. This is not a race motor I assume, and the pros argue the benefits of rod length. The possible gains being small, i wouldn't worry about it much.
