Re: Tuning Results From An O2 Kit?
[Re: Mattax]
#937110
09/14/11 10:13 AM
09/14/11 10:13 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
Mattax, ""So my question is this whether the lean surge also occurs above the PV opening vacuum?"" - No it does not.
""However when the PV does open, the AFR should not get suddenly leaner if the carb is already on the mains (even partialy). Check the AFR at 12" and 10". If its already around 16:1 or higher, then 16:1 at 9.5"vac at least makes sense. If AFR is richer at 10 and 12"Hg than at 9", then something is not right.* If its continuing to get leaner below the PV opening vacuum then the PV is probably not opening when it should be.""
- I will check that out once I get the carb back together.
Thank you for your response.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#937112
09/18/11 11:09 PM
09/18/11 11:09 PM
Posts: 598 NC, USA
davenc
NC, USA
Y07_A66:
How long does the lean AFR last? Does it persist for more than 1 second while accelerating? How are you controlling the vacuum level the engine encounters? Are you loading the engine with the brakes or up a long hill? Lastly, do you know if the secondaries are starting to open during your acceleration runs?
The AP should only cover a short duration lean period immediately following the throttle opening, unless it dumps too much fuel, which will then require the motor some time to recover from. It is possible that the total volume from the pump is correct, but the timing is not optimal. This could be particularly true on the secondary side if those throttle plates are starting to open, since you did a bunch of work to limit the accelerator pump volume coming on that side.
I might be influenced by your answers above, but the other thought I have is that the lean spot is actually occurring before the PV opens. The PV might not be opening at the right point, and the wideband also has a bit of latency in it, so the AFR will be a lagging indicator.
[Re: davenc]
#937113
09/19/11 07:41 AM
09/19/11 07:41 AM
YO7_A66
Indiana
Dave, * How long does the lean AFR last? - Until the 3-2 downshift occurs. * Does it persist for more than 1 second while accelerating? - It stays lean during accel. * How are you controlling the vacuum level the engine encounters? - I have a guage inside that I use to observe the vacuum. I am not sure that I answered your question though. * Are you loading the engine with the brakes or up a long hill? - No. Just a slow steady increase of speed from a stop but not enough for the 3-2 downshift to occur. * Lastly, do you know if the secondaries are starting to open during your acceleration runs? - Not for sure, but I am trying to stay out of them to tune this issue. I am going to disconnect the seconds on my test drive and test a couple of changes on the primary side. * The AP should only cover a short duration lean period immediately following the throttle opening, unless it dumps too much fuel, which will then require the motor some time to recover from. It is possible that the total volume from the pump is correct, but the timing is not optimal. This could be particularly true on the secondary side if those throttle plates are starting to open, since you did a bunch of work to limit the accelerator pump volume coming on that side. - Good point. Maybe while I am trying to stay out of the seconds, they are actually starting in and causing the lean period. Once I retest with my seconds disconnected, maybe I should go back to the 60% secondary delay (currently 40%) and see if this changes. * I might be influenced by your answers above, but the other thought I have is that the lean spot is actually occurring before the PV opens. The PV might not be opening at the right point, and the wideband also has a bit of latency in it, so the AFR will be a lagging indicator. - The lean spot is definately happening before the PV opening. I am using a 9.5 but I also have a 10.5 to test with. But with the lean spot happening upwards of 12hg, I am assuming that it is somewhere else. Now that you pointed out the secondaries opening, I might just need to delay the seconds to the 60% point or speed up the secondary cam by one hole. EDIT: After thinking about what you wrote about the secondary throttle plates opening at my current 40% delay mode, and since I delayed the timing of the secondary cam so much to delay the volume, I bet that is creating a lean spot at 40% throttle. I am pushing down a bit on the throttle to make the 9.5pv open up. That has to be the cause!!!!!!!!! I don't want the secondaries opening that quick, so I am going to swap the secondary linkage back to the 60% and retest. Thank you very much for your responses. They help to pull the blinders off when I am trying to test so many different combos!! ![](/ubbthreads/images/graemlins/grin.gif)
[Re: davenc]
#937117
09/21/11 07:32 AM
09/21/11 07:32 AM
YO7_A66
Indiana
""Given the duration of lean period, and on the assumption that the secondaries are beginning to open, it seems the problem may be more than just the secondary AP. What are the current values of IAB and IFR on the secondary side? You may need to ponder the transition circuit behavior on the secondaries.""
- Since I have the secondary pump cam delayed so much, this is my guess on the long lean spot. I have delayed the secondary opening rate to 60% and I have made a few other changes and now I just need to find some time to get out and drive. This lean spot is not an issue during most of my normal driving time. It only happens when I try to accel and not have the tranny kickdown. When I accel harder and the tranny kicks down, the A/F is fine. I am just trying to tune the bugs as they come up and this one got my attention. I am going to test the secondary delay and see what happens.
""What are the current values of IAB and IFR on the secondary side?"" - .031" IFR's and .064" IAB's. (Same on front) Thank you both for the replies.
[Re: YO7_A66]
#937118
09/21/11 09:25 AM
09/21/11 09:25 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Relationship of jets to restrictions: If there are two restrictions in series, and one restriction (main jet) is approximately 4 times the area of the second restriction (IFR), then there should be little or no effect. I agree that's not always absolute as other variables play a role and area is not the only determinant of flow (especially on Holley Main jets). There are some good discussions on this relationship if you dig back through the Innovate, Speedtalk, and Motorsports Village forums.
Secondary Accelerator Pump Cam: That needs to be providing the fuel when the secondary throttle is on the transition. It needs to start moving as soon as the secondary throttle starts to move. It is needed because the fuel coming out the transition flow is based on the difference between the atmospheric pressure and the manifold pressure (in other words, vacuum). That flow not going to respond to a quick movement of the throttle (which reduces the vacuum at least momentarily)
Disconnecting the secondaries for testing purposes is the other option.
IFR, IAB: Interesting. Compared to what I've seen, and waht people post on forums like Innovate's, that's a pretty small idle air bleed relative to the idle feed restriction. However I can't recall anyone else really spending the time you have with an annular boostered carb. The carb I'm currently working with also has annular boosters (installed by QF) in the primaries. Right now it has .028 IFRs and .073 IABs. Next chance I get will be to try .026 IFRs and then that's probably the end of my experiments with that carb.
[Re: Mattax]
#937119
09/21/11 10:45 AM
09/21/11 10:45 AM
YO7_A66
Indiana
""Compared to what I've seen, and what people post on forums like Innovate's, that's a pretty small idle air bleed relative to the idle feed restriction. However I can't recall anyone else really spending the time you have with an annular boostered carb.""
I have spent many hours searching the other sights looking for a good tuning reference on an annular carb. They are out there, but there is not much detail in how they tuned the carb and how they ended up in the tuning process. I have not found anyone that is using the smaller 60 main jets. I have found some using the .031 IFR's though. Mine came stock with .033" IFR's so I am fairly close. My carb cam stock with 068 main jets, but this just proves that with some tuning, the A/F numbers can be achieved. I have tried larger main jets but I had to use the larger IAB's to compensate for the cruising 30-60mph A/F. Then when I used the larger jets, the 60mph+ cruising A/F numbers went way fat. So my current .064" IAB's are just a tool to lean out my A/F numbers slighty to keep me in the upper 14's to low 15's. Actually, the last numbers that I posted were with 60 main jets and .060" IAB's. I want to lean those numbers out slightly so I put in some .064's and that should do it.
I started my tuning with the .028 IFR's and using the stock .071" IAB's and found my 30-60mph cruising A/F from 15.5-16.5. That is when I changed to the .031's and have been using them since. Then as I change the main jets, I then compensate with the IAB's to get my cruising A/F where I want it. I talked with QF about the 60 main jets, and they were surprised to see such a low jet but they also said that the annulars do pull allot of fuel and as long as I am getting the A/F numbers, then tune away. My vacuum gauge shows "0" at WOT, so the motor appears to be happy. Note: My stock main jetting and stock pvcrs sizes were .068 and .059. I am now using the .060 main jet and .069" pvcrs which equate to the same volume.
[Re: davenc]
#937122
09/21/11 10:08 PM
09/21/11 10:08 PM
YO7_A66
Indiana
"but given how long the leanness persists, it seems there may be something affecting fuel flow in the secondaries with small secondary blade openings."
Dave, I delayed the secondary cam a BUNCH! The secondary blades were difinately opening way before the cam was sending fuel. Once I get the curve set back up, I will retest the secondary cam timing to fix that issue. Thanks
[Re: davenc]
#937123
09/21/11 10:12 PM
09/21/11 10:12 PM
Mattax
Phila. Pa.
Mattax,
Am I understanding your statement regarding the IAB size to imply you expect the booster type to have an effect on the transition circuit behavior?
I beleive it's a possibility because the main circuit may contribute sooner with an annular booster than a straight leg. Another factor is the size of the booster. The boosters that Quick Fuel installed on the 3310 that I'm working with are huge. So that should induce the mains to start sooner but of course the high speed air bleed and emulsion holes can effect that. Bottom line is that I'm just curious about what other people have found with annular boostered carbs.
[Re: davenc]
#937125
09/30/11 02:44 PM
09/30/11 02:44 PM
YO7_A66
Indiana
The weather has not allowed me to test any changes, so until then, I wanted to discuss this chart. Every since Spring when I installed the sensor, I have been tuning to get my WOT at the 12.6/12.8 range while thinking that 14.7 was my stoich target. Then I read this chart and I am running 10% Ethanol. It appears that I should be aiming for 12.2 WOT and thinking that 14.1 should be my stoich (Neutral/In D target) which is allot closer to what my engine wants versus the 14.7 target. It appears that I need to rethink my tuning by .5 A/F or so. I will still tune to what the car wants but this chart makes me rethink my numbers just a tad, especially my WOT target.
[Re: davenc]
#937127
10/02/11 08:34 AM
10/02/11 08:34 AM
YO7_A66
Indiana
""but am curious as to how reliable the source is.""
I tried to find it but I am pretty sure that a FAST rep showed the chart in another thread. The chart is an interesting reference and now that thy are talking about E15, this would give us a good tuning reference if this takes place.
While trying to get to the magical 14.7 number, I have found that the engine wants what it wants. I know that I can not go any leaner on E10 than 15.8 on cruise, but after seeing this chart, I see why people are aiming for different numbers. I may shift my A/F range down from 14.5-15.5 max to 14.0-15.0 based on this chart. Or, not worry about my low 14 number during cruise thru out the temp changes of the year.
[Re: YO7_A66]
#937128
10/09/11 02:32 PM
10/09/11 02:32 PM
YO7_A66
Indiana
The last issue was trying to find out why my light to medium accel was showing 16+ on the A/F meter. I delayed the seondary from 40% to 60% and also added a more aggressive primary pump cam and this helped a little but was still showing mid 15's to low 16's and the car does not like the upper 15's and started surging under accel. Since I need more fuel under accel and since reading more about the A/F ratio of E10, I decided to richen my existing 30-70mph cruising A/F range that was showing 14.2-15.4. Since my driving season is quickly coming to an end, I decide to make a few changes at the same time: 60 primary jets to 62's .069" PVRC's to .071's 9.5HFPV to a 10.5HFPV green primary pump cam to an orange With these changes there was only about 20 minutes and 2 degrees difference in outside temps (high 50's) and what a big difference in power!! My light/medium accel was now showing 13.8-14.4. I could feel the difference in power while the A/F gage was in this range. My cruising range richened up by about .5 on the gage. The E10 chart shows stoich at 14.1 and I am happy with mid 14's instead of low 15's from 30mph to 4000rpms. What really surprised me is how flat my A/F range is now. 30mph = 14.2 35mph = 14.4 40mph = 14.2 45mph = 14.6 50mph = 14.6 55mph = 14.4 60mph = 14.2 3500rpms = 14.2 4000rpms = 14.2 I am done with the primary side!!!!! (62 jets, .064 IAB's, .039" HSAB's, .031" IFR's, .071 PVCR's,)
I then looked at my 50mph to WOT and found a spike to 12.2 and then it leaned out to 13.0 at the shift point. After reviewing the E10 chart, the WOT should now be 12.2 instead of the gasoline 12.6. I am going to richen up the secondary side by 2 jets and see if that keeps the A/F in the low 12's. I also made a rolling start to WOT and my A/F spiked to 12.4 and then leaned out to about 13.4 at the shift point. This is too lean so I am hoping that the secondary jet change takes care of this. The last thing that I tested was the overall hard acceleration with the 62 jets and the .071" pvrc's and I was surprised. The car pulled harder now with this combo than it ever has. It likes the .071" pvrc's with the 62 jets. I have no issues with the main side of the carb and now I just want to tweak the secondary jetting with the 60% delay. Note: I still have the secondary pink pump cam turned counter-clockwise as far as it will go which creates a gap between the pump cam and the pump arm screw. There is no drivability issues with this setup during my normal driving which is fairly aggressive and my WOT A/F is 90% there.
UPDATE: 75 degrees: 80 secondary jets made my 50mph to WOT show 12.8. The 78 secondary jets made a 13.4 WOT run, so it looks like I need to try some 82's next.
