Leaf springs #936758
02/24/11 10:34 PM
02/24/11 10:34 PM
ohio
geol Offline OP
geol  Offline OP
ohio
Is it possible to change the bushings on the front of the leaf springs on a 72 Duster?If so where might they be found?
Re: Leaf springs [Re: geol] #936759
02/24/11 11:30 PM
02/24/11 11:30 PM
On your drill press, drill the rubber in multiple spots around in a circle till it's free. On the vehicle you will need the correct puller to pull the center metal bushing and the rubber out of the big eyelet
