Brake Booster #936585
02/24/11 07:55 PM
02/24/11 07:55 PM
Michigan,Macomb County
RTChargerman Offline OP
Hello, I need some HELP !! I have a 1970 Dodge Charger,The car had 4 wheel power drum brakes, I did the front disc brake 73-76 a-body swap, need to know if the old brake booster will work with this swap. Thanks
Re: Brake Booster [Re: RTChargerman] #936586
02/24/11 08:17 PM
02/24/11 08:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Yes it will, just be sure to use the proper disc/drum master cylinder, and change out the drum brake only distribution block for the proper disc/drum proportioning valve body
Re: Brake Booster [Re: DAYCLONA] #936587
02/24/11 08:34 PM
02/24/11 08:34 PM
THANKS FOR THE HELP !!!!
