Page 1 of 4 1 2 3 4
1970 Road Runner . with a BIG bullitt UPDATED #935472
02/23/11 12:57 PM
02/23/11 12:57 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Pictures are worth a thousand words
Re: 1970 Road Runner . with a BIG bullit [Re: gtx6970] #935473
02/23/11 12:59 PM
02/23/11 12:59 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
493 cu.in. well over 700 hp
I'm dieing to hear this one run, this should be fun.
Re: 1970 Road Runner . with a BIG bullit [Re: gtx6970] #935474
02/23/11 06:43 PM
02/23/11 06:43 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
NICE
Re: 1970 Road Runner . with a BIG bullit [Re: MuuMuu101] #935475
02/23/11 07:12 PM
02/23/11 07:12 PM
Vandergrift,PA
The70RTChallenge Offline
Vandergrift,PA
Looks like lots of fun!! Post some more pics from throughout your project. Bettin it'll be a tire eater
Re: 1970 Road Runner . with a BIG bullit [Re: The70RTChallenge] #935476
02/23/11 09:15 PM
02/23/11 09:15 PM
I am curious about the engine combo, I have a 493 which I still need to assemble and dyno.
Re: 1970 Road Runner . with a BIG bullit [Re: ] #935477
02/24/11 09:01 AM
02/24/11 09:01 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I'll be talking to the owner later this week, so I'll see what I can find out. As I didn't build it. I just get to put it in. and fire it up
Re: 1970 Road Runner . with a BIG bullit [Re: gtx6970] #935478
02/24/11 04:45 PM
02/24/11 04:45 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Can't wait to see the Dyno numbers Over 700 HP? Cool. I wish my 496 made that much HP.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: 1970 Road Runner . with a BIG bullit [Re: gtx6970] #935479
02/24/11 05:39 PM
02/24/11 05:39 PM
Hinckley, Ohio
KWF340 Offline
KWF340  Offline
Hinckley, Ohio
Here is the thread for this build
Link
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
Re: 1970 Road Runner . with a BIG bullit [Re: KWF340] #935480
02/24/11 06:33 PM
02/24/11 06:33 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Link
Thanks Ken
And on a side note, today went well.
And with no issues it should be be back in the chassis early next week.
All the clutch components are in. Scattershield was already doweled so I didn't have to worry about dialing it in. And it's now painted and installed with all new grade 8 hardware, and I even remembered to put the block saver on.
Got the trans stripped and painted today. So it will be connected tomorrow afternoon.
Nobody had header gaskets for a big block mopar on hand.so they should be in in the am. But all in all , today was good day.
Re: 1970 Road Runner . with a BIG bullit [Re: KWF340] #935481
02/24/11 07:45 PM
02/24/11 07:45 PM
S.E. Conn
S.E. Conn
Link
Wow. All that with a 4spd behind it. Envious.
2005 300C Hemi
Re: 1970 Road Runner . with a BIG bullit [Re: Hoof Hearted] #935482
02/26/11 11:00 AM
02/26/11 11:00 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Trans was all scratched up and painted hemi orange. Which just blends on against the Vitamin C Orange floor pans.
So, it went from this,,,,,,,,
Re: 1970 Road Runner . with a BIG bullit [Re: gtx6970] #935483
02/26/11 11:05 AM
02/26/11 11:05 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Wire brush didn't phase it, so I had to use chemical stripper to get it off
Re: 1970 Road Runner . with a BIG bullit [Re: gtx6970] #935484
02/26/11 11:07 AM
02/26/11 11:07 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Now all finished in Cast iron coat, to give it that bare steel look
Re: 1970 Road Runner . with a BIG bullit [Re: gtx6970] #935485
02/26/11 11:09 AM
02/26/11 11:09 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Hit a little snaffu,
Turns out the water pump housing is a 69 and older casting, with the heater hose nipples being the same 5/8" size.
Car is a 1970 and thus requires a one at 1/2" and one at 5/8"
Re: 1970 Road Runner . with a BIG bullit [Re: gtx6970] #935486
02/26/11 11:15 AM
02/26/11 11:15 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Did a bit of digging and came up with a nipple with the 3/8" NPT size and yet it has the port size for the the 1/2" heater hose. Much easier then tracking down a new water pump hsg.
Re: 1970 Road Runner . with a BIG bullit [Re: gtx6970] #935487
02/26/11 11:20 AM
02/26/11 11:20 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
With a brand new water pump installed, all the pulleys installed with new hardware, upper and lower radiator hoses are now on with new clamps.
With a little luck we'll be mating the engine and trans back together this weekend. And be re-installing it all back in the chassis on sunday afternoon
Re: 1970 Road Runner . with a BIG bullit [Re: gtx6970] #935488
02/26/11 11:26 AM
02/26/11 11:26 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
This is the back side of the long block to show how the Indy Cyl. heads are oil fed.
Re: 1970 Road Runner . with a BIG bullit [Re: gtx6970] #935489
03/16/11 02:37 PM
03/16/11 02:37 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Updated, after a bit of a quandry getting the hydraulic throwout bearing configured and set like it's supposed to be.
The Bullit is in
and I like it
Re: 1970 Road Runner . with a BIG bullit [Re: gtx6970] #935490
03/16/11 02:38 PM
03/16/11 02:38 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
other side
Re: 1970 Road Runner . with a BIG bullit [Re: gtx6970] #935491
03/17/11 09:26 PM
03/17/11 09:26 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Needing someplace to mount the MSD box became an issue. Away from major engine heat and/or any moving parts.
I had looked into installing it under the dash, but with it being a 4 speed car ruled that out quickly.
So, next logical choice was under the battery tray. And so I'm told will not be an issue with extending the units wiring.
Page 1 of 4 1 2 3 4
