Hi...
I'm totally a newbie on this forum
First of all, let me introduce me :
I'm a French Canadian, now living in France. I'm owning a 1971 Barracuda Gran Coupe 383 (matching #) The car was sold new in Switzerland, where I've bought it.
Lately, I've rebuild the engine. Beside the block, crank and rods, everything is new. The engine is slightly modifie, but still a 383.
I do have a light problem with the acceleration.
On the idle, the engine turn perfectly, but if I put the pedal to the metal, there's power, but rapidly nothing for many seconds, then it takes it rpm perfectly.
There's nobody who know's how to tune a Holley at 200 miles around me... So... Im' asking for a little help.
I've got a 670 Street Avenger on a 383 that must have around 400hp.
My psi is around 12.5, the power valve is a 65
The pump nozzle discharge is a 37 (how do I calculate a good one?)
The cam on the carb is the yellow one (how do you figure the one to use?)
The spring is the pusple one...
Where should I look? Start? For the moment
Thanks a lot and best regards from oversea
PS: There's less than 10 Barracuda/'Cuda 71 in this country
