either one could it be nice. I think a Motorhome can't get ever an small alt. The best you can do is take it to a test to a shop.
PNs are usefull BUT just if comes from tag if still present. Housing PNs are the same to several alts. The big diff its on the stator being wider and smaller gauge windings to fit more, but they don't have a PN
HOWEVER, I can be some agreed with Robert than the 80 truck could it be the best option just looking at it. Those are bigger stator by fact, and the smaller ones are 60 amps ( bigger than any average alt from earlier 70s and all 60s ), some other were 78 amps
BUT being the other one come out from a motorhome, would take both to a shop and test them. The earlier one will fit easier on stock location. The later will fit, but tight
