Re: Tuff Wheel
[Re: 10secGTX]
#933892
02/21/11 07:50 PM
02/21/11 07:50 PM
Posts: 4,518 Indiana
MonGoo$e
Indiana
I would imagine you need the factory tuffwheel/rim blow adapter, had the splines base like a regular steering wheel, the body, then the 3 studs to mount the wheel with the small lug nuts.
Re: Tuff Wheel
[Re: MonGoo$e]
#933894
02/21/11 11:50 PM
02/21/11 11:50 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I bought my adapter at the Carlisle swap meet. There were bunches of them. I used it on a new Tuff Wheel I bought from BE & A. I put this on my '72 Charger.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Tuff Wheel
[Re: dfsmopars]
#933895
02/22/11 12:11 AM
02/22/11 12:11 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
guys, take in mind the 70s columns were bigger diameter 'cause the new ign switch location. Original tuff/rimblow wheels adapters are made to this new diameter since they floated on in 70s
there is not exist original adapters to 69 and earliers columns, will need an aftermarket one.
Re: Tuff Wheel
[Re: NachoRT74]
#933896
02/22/11 01:21 PM
02/22/11 01:21 PM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
So this is not possible to do then ?
Re: Tuff Wheel
[Re: DGS]
#933900
02/23/11 01:55 AM
02/23/11 01:55 AM
NachoRT74
Valencia, España
weeeeell... dunno... if you like how it looks outside the collar. Definitelly not my cup of tea
Nice job though!
