Re: 4bbl vs six pack
[Re: Mr.Yuck]
#933360
02/23/11 03:30 PM
02/23/11 03:30 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
my stock six pack setup ran the same as a 1000hp holley on a victor with 493, rpm heads, 590 mp cam
the weiand cross ram with a six pack was good for .2 and 2mph in the 1/8th if i remember correctly
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Mr.Yuck]
#933361
02/23/11 04:22 PM
02/23/11 04:22 PM
Posts: 2,826 NY usa
540challenger
NY usa
Any more MPG numbers out there to share?
70 Charger 440/6 450 HP, DANA 60 4:10, 28" tire, Keisler 5spd TKO .64OD avg 22 MPG,....on the hand my Challenger T/A, 340/6 4" stroker 443 RWHP, factory 883 4spd, 3;91, 28" tire gets about 10 MPG
that's because you have to spin the SB to get the HP numbers.
More likey the overdrive is making the difference It is a stroker small block making the same rwhp as the 440flywheel hp"just notice that part " it has nothing to do with "reving to make power"
