Ford Bullitt Wheels on 8.75 rear end #932421
02/19/11 04:57 PM
02/19/11 04:57 PM
Marietta, GA
Joatha Offline OP
Joatha  Offline OP
Marietta, GA
With my 8.75 rear not installed, I was doing some measuring and checking. I have a set of Mustang Bullitt wheels (which I love the look of) and mounted them up on the rear while it was on sawhorses. I noticed that the center register didn't clear the wheels (which I sort of expected). Its just barely too small for the axle. Is the way to fix this to grind out the wheel? Or should I take a little off the axle?
If I do this to the wheels, will it be OK to just use a stone head on the end of a drill and remove material? Or do I want to get a machine shop to remove a specific amount so that it will sit flush? Or do I take the axles to a machine shop and have them remove a specific amount?
Just making sure I do this right.
1966 Barracuda 1968 Barracuda convertible 1930 Ford Model A (soon to be hemi equipped) 2006 Dodge 3500 4X4 CTD Quad Cab
Re: Ford Bullitt Wheels on 8.75 rear end [Re: Joatha] #932422
02/19/11 05:48 PM
02/19/11 05:48 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Anyone with a lathe can easily machine the register on the axle to the necessary diameter.
Re: Ford Bullitt Wheels on 8.75 rear end [Re: DoctorDiff] #932423
02/19/11 10:32 PM
02/19/11 10:32 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
I'd machine the wheels before I'd machine the axles to keep the brake drums hub centric.
Just what I'd do personally.
Re: Ford Bullitt Wheels on 8.75 rear end [Re: rabid scott] #932424
02/19/11 10:54 PM
02/19/11 10:54 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Grind the wheels. Notice that when you buy aftermarket wheels, 'specially a unilug type wheel, the center does not "register" on the axle.
I agree, do NOT grind on the axle.
Re: Ford Bullitt Wheels on 8.75 rear end [Re: Joatha] #932425
02/19/11 10:57 PM
02/19/11 10:57 PM
IMGTX Online content
IMGTX  Online Content
I was going to run them on my car until I discovered the offset wasn't in the ballpark of what I needed. I don't like adapters so I am looking at something eles.
Just an FYI before you get too into it.
Re: Ford Bullitt Wheels on 8.75 rear end [Re: Yancy Derringer] #932426
02/20/11 12:00 AM
02/20/11 12:00 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The wheel register on the axle steps up to the brake drum.
Machine the (outer) wheel register, NOT the (inner) brake drum pilot.
Re: Ford Bullitt Wheels on 8.75 rear end [Re: IMGTX] #932427
02/20/11 12:59 AM
02/20/11 12:59 AM
Marietta, GA
Joatha Offline OP
Joatha  Offline OP
Marietta, GA
Yeah, I know about them. I am going to run a B-body rear in my Barracuda. So, that will buy me a bit more room and allow the extra backspace to work. I'm running AndyF's Viper disk brake kit on the front so it necessitates a heavy backspace on the front. Since I needed to put a 8.75 in anyhow, I chose a B-body. I plan to move the perches in to A-body specs (debating about going .5" more) to give me the clearance I need.
Re: Ford Bullitt Wheels on 8.75 rear end [Re: Joatha] #932428
02/20/11 03:39 AM
02/20/11 03:39 AM
AndyF Offline
AndyF  Offline
Turn the axles down like Cass suggested and then you'll be all set to run the Mustang rims. You don't need to take much off, just turn it down until you have about 0.005 clearance.
That will give you a bolt together system that will allow you to swap on different Mustang wheels in the future. It is more common to change wheels than axles so it makes more sense to modify the axle.
Re: Ford Bullitt Wheels on 8.75 rear end [Re: AndyF] #932429
02/20/11 01:41 PM
02/20/11 01:41 PM
Marietta, GA
Joatha Offline OP
Joatha  Offline OP
Marietta, GA
The brake register for a Ford is 2.525". So, I should be able to turn it down to that and it should work. There is a small lip in the wheels that is likely there to clear the Ford register.
I don't have any 10x2 (or 2.5) drums yet for this. Anyone know how thick the drums are?
Re: Ford Bullitt Wheels on 8.75 rear end [Re: Joatha] #932430
02/20/11 05:37 PM
02/20/11 05:37 PM
AndyF Offline
AndyF  Offline
The center bore in the Mustang rims should be 2.780. The hub is usually 0.004 or 0.005 less than that.
Mopar wheel register is 2.813 so it is just a tiny bit larger.
Re: Ford Bullitt Wheels on 8.75 rear end [Re: AndyF] #932431
02/21/11 10:07 AM
02/21/11 10:07 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
the bullit rims have a chamfer on the wheel, some 1/8" spacers will be enough to fit over the mopar rear axle flange w/o any machining...
ease of use, if you can find a small bore ridge reamer (say for a briggs & stratton), you should be able to shave .030" off of the wheel bore to fit the axle....
2017 Grand Cherokee Overland
Re: Ford Bullitt Wheels on 8.75 rear end [Re: patrick] #932432
02/21/11 01:15 PM
02/21/11 01:15 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
We've run the Mustang wheels for years by just taking a 2" drum roll sander to the rims. We do the rims so we can interchange them between different cars; doing the axles works, too. I run 16" Pony rims on my Caravan and a friend has 3 Intrepids or 300M's with GT or Bullet rims. The 114.3 metric rims are the same as 4.5" bolt pattern, so you'ld be surprised how many rims actually fit the older cars. Really makes the tire monkeys at Belle Tire scratch their heads, too!
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Ford Bullitt Wheels on 8.75 rear end [Re: patrick] #932433
02/21/11 08:46 PM
02/21/11 08:46 PM
Marietta, GA
Joatha Offline OP
Joatha  Offline OP
Marietta, GA
There's a part of me that wonders if I could knock enough off if I just took a metal file to the edge of the axle registers and filed them off evenly instead of taking them to a machine shop. It shouldn't require much material coming off.
