Re: Hard starting with 600 Edelcrap when hot
[Re: Supercuda]
#931707
02/18/11 09:16 PM
02/18/11 09:16 PM
RapidRobert
I did miss that this carb ran OK on another vehicle. Correct it is not the carb. I have an eddy 600 (1406) w a stock 318 pump & it starts OK tho mileage is terrible (maybe it's flooding some)
[Re: BDW]
#931708
02/18/11 09:31 PM
02/18/11 09:31 PM
Posts: 27,728 places
79powerwagon
places
Unless you go thicker than the Edlebrock gasket I doubt you'll see any difference. It's basically the same thing as a 1/4" phenolic spacer.
Back in the 90's when I bought my first new 1406, I called tech support who told me that these carbs NEED a 4 hole spacer under them to flow properly. Sure enough, I tried one and eliminated almost all issues, the rest were worked out with proper tuning. Why they simply don't say that in the owner's manual is a mystery...
The thickness of the spacer matters, too. It depends on your engine build and health. The 360 in my W150 needed 1.25". The poly 318 in my 64 Fury needed 1/2". The 440 in the Charger was 1". Just food for thought.
[Re: GO_Fish]
#931712
02/18/11 11:10 PM
02/18/11 11:10 PM
Posts: 15,487 Florida
scratchnfotraction
uhh!! i think that is why the stacked alum plate style heat disapater works so well over a solid spacer and 1 gasket for each side
those alum plates never touch the carb,carb stays luke warm on a blistering summer day drive
intake/gasket/plate/gasket/plate/gasket..ect carb sits on top of last gasket
and its a 4-hole spacer for a better vac signal
worked the best here in fl on mine in dog days of summer
[Re: scratchnfotraction]
#931713
02/18/11 11:16 PM
02/18/11 11:16 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
If you are talking about the aluminum plates that stick out way past the gasket, yes those would in theory act as a heat sink to keep heat away from the carb. But it all depends on the underhood temps. If the temps are higher than the aluminum plates, then heat is going into the plates instead of out of them. Aluminum heat transfer works both ways, I'd rather rule it out.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
