How much cam advance is too much? #931129
02/17/11 02:38 PM
02/17/11 02:38 PM
Essex, Ont., Canada
Fishmarket Offline OP
Essex, Ont., Canada
I have a 418 sb with ported eddys, RPM Air Gap, Bigs 950, 10.5 to 1 etc etc. The cam is a comp custom; XFI Lobes, 242/248 on a 108 LSA. I want to get the dynamic compression close to 8.2 and have the cam installed 7 degrees advanced (engine has not been run yet). Is this too much? I hoping that the cam is small enough that it won't be a problem.
The engine is going in my mostly street, 4 speed cuda with manual brakes.
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: How much cam advance is too much? [Re: Fishmarket] #931130
02/17/11 02:46 PM
02/17/11 02:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When the valve hits.... thats too much... you will
keep closing the intake sooner (piston is down farther
in the bore) so it will make more low end torque but
you also loose top end out of it (you move the whole
power band lower in the rpm range)
EDIT
I ran one cam(108 LSA) at 99*... had the torque but
I didnt need that much and I ran out of top end so
I went to 102 or 104 ..... but with your stick you
have a steeper first gear so even the the 7* MIGHT
be too much but we dont know the weight of the car
and your rear gears and tire size..... it all matters
Re: How much cam advance is too much? [Re: MR_P_BODY] #931131
02/17/11 03:06 PM
02/17/11 03:06 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Great question. My cam(254 int. 259 exh @ .050, .644 and .649 respectively) was ground on a 112 LSA and said to install to 110 degrees. I came up with 111, but was told I could increase my low end if I advanced it 2 degrees. I didn't because it's a 505 stroker BB, and it should need too much low end. Hope my reasoning wasn't too far off.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: How much cam advance is too much? [Re: ChrgrCuda] #931132
02/17/11 03:13 PM
02/17/11 03:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My cam is a 112 LSA and I have it installed at 108...
how much torque do you need, thats the question...
as you gain the torque you also sacrifice top end
rpm.... most street cars can use the low end because
you dont go all that high in the revs
EDIT
your correct you have the CI to give you the torque
Re: How much cam advance is too much? [Re: Fishmarket] #931133
02/17/11 05:00 PM
02/17/11 05:00 PM
Az
Crizila Offline
Crizila  Offline
Az
On this web sight, there is no such thing as advancing the cam too much.
Fastest 300
Re: How much cam advance is too much? [Re: MR_P_BODY] #931134
02/17/11 05:01 PM
02/17/11 05:01 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
EDIT
Thanks as Always Mr.P-Body. And I apologize to the OP for the hijack.
Re: How much cam advance is too much? [Re: MR_P_BODY] #931135
02/17/11 05:04 PM
02/17/11 05:04 PM
UK
602heavy Offline
602heavy  Offline
UK
Tis a double edged sword when advancing intake centreline , obviously what this does is advance all valve events , too much advance can have the exhaust valve open too soon , especialy bad when running low compression engines with slow flame travel , sometimes the split pattern grinds just make matters worse , the other problem is reversion through intake @ low rpms , not good for a street motor.
Re: How much cam advance is too much? [Re: 602heavy] #931136
02/17/11 06:15 PM
02/17/11 06:15 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I was told that if you change the cam timing 6 or more you have the wrong cam for best results
Re: How much cam advance is too much? [Re: 602heavy] #931137
02/17/11 06:31 PM
02/17/11 06:31 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Sorry to jump in, but if cam is in early (Mine is at 101-102, ground on a 108) can this cause problems with idle quality..maybe due to reversion?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: How much cam advance is too much? [Re: 602heavy] #931138
02/17/11 09:30 PM
02/17/11 09:30 PM
Essex, Ont., Canada
Essex, Ont., Canada
That's what I'm asking about... my cam is in 7 degrees advanced. Would changing it to 5 degrees make that much of a difference? Doesn't comp grind most of their newer shelf grinds with 4 degrees built in? Wouldn't the "downsides" be exacerbated on a cam with 25 degrees more duration?
Assuming piston to valve clearance is not an issue.
Thanks for your responses.
Re: How much cam advance is too much? [Re: Fishmarket] #931139
02/17/11 09:45 PM
02/17/11 09:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Every cam company that I know of puts in 4* and then
MOST still add more... whats the weight of the car,
gear ratio and tire size... this is mostly a street
car correct
Re: How much cam advance is too much? [Re: MR_P_BODY] #931140
02/17/11 10:04 PM
02/17/11 10:04 PM
Essex, Ont., Canada
Essex, Ont., Canada
Not sure of the weight yet, mostly street car, 4.10 rear, 275 60 15 tires.
Re: How much cam advance is too much? [Re: Fishmarket] #931141
02/17/11 10:06 PM
02/17/11 10:06 PM
UK
602heavy Offline
602heavy  Offline
UK
& that's a good question...................you cam the motor for the application , a 440 street motor would be a dog down low when increasing duration 25 degrees , some guys like the sound of a lopey idle in their stock motors , take two stock 440s , both have the same duration #s @ .050 & both ground on a 110 lsa , only difference being duration #s @ .004"/.020" , the guy with more 'lope' will usually be leaving power on the table , overlap is a bad thing @ low rpm (street motors).
Re: How much cam advance is too much? [Re: Fishmarket] #931142
02/17/11 10:17 PM
02/17/11 10:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A 72 cuda weighs a fair bit but that being said I
think I would put it in at 104 and try it... you
are running a stick and a decent gear so you should
be fine coming off the lights to impress plenty
of the people..... JMO
Re: How much cam advance is too much? [Re: Fishmarket] #931143
02/17/11 10:30 PM
02/17/11 10:30 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Seems the older style flat tappets respond better advanced. I have run them as much as 102-103 ICL. Mostly the older MP cams anyways.
Im with the others. If the cam is advanced that much, its probably the wrong cam. Although I will say the old MP 590 runs well in at 102-103 ICL.
Most of the modern grinds I have run (flat tappets) maybe 3-4 in the past 5 years were custom pieces, they didnt need to be advanced as far, but the also had wider lobe centers than the older stuff. 106-108 ICL is typical. I can't see a custom cam needing advanced like the older stuff. Unless the cam builder just missed the profile.
I have never run a solid roller more than 107 ICL..Usually 108-109 is typical.
I had a few old Crane Pro stock Hemi cams I wanted to play with.. these cams have narrow LSA 104 was typical, I wanted to play with the cam's ICL, but found out I was out of room in valve margins. These designs are better suited for Stage V heads and Indy hemi heads that have the rotated exh valve...
But Ideally these old grinds are a good conversation piece....
A custom cam give a much better power range, just a over better cam.
I also have the small MCcandless Comp grind in a car (450cid Duster engine with)275 .575 and the old .650 comp grinds and these along with the MP 590 are about the only exceptions to the super advanced cams...103 or more is common.
I dont know how in the world these cams run like they do. I showed those specs to my machinist and he just laughed. I dont know why they run, but they perform very well for old grinds.
Re: How much cam advance is too much? [Re: Fishmarket] #931144
02/17/11 10:53 PM
02/17/11 10:53 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
With that size cam your fine! Your "lift events" are well within the norm of "lift windows" on both the intake and exhaust. Whats the Norm you say
In general as long as your advanced cams "lift events" falls within a 20* range, with the Window of cams, selected between 230* @ .050 and 270* @ .050
EDIT!EDIT EDIT!EDIT!EDIT!
"Not to be confused with 20* of advance"
You advanced yours 7* so your sitting at 20* BTDC and 42* ABDC on the intake.
How does that compare to other cams "intake timing events.
10* BTDC, 42* ABDC 232* @.050 cam
20* BTDC, 48* ABDC 248* @.050 cam
30* BTDC, 60* ABDC 271* @.050 cam
The exhaust events, yours, @ 7* advanced.
59* BBDC, 9* ATDC "yours"
The other cams events.
47* BBDC, 7* ATDC 234* @ .050 cam
56* BBDC, 12* ATDC 248* @ ,050 cam
70* BBDC, 24* ATDC 275* @ .050 cam
I think your good to go, the intakes shutting a little early but you still have its 242 dur.@ .050, it will still rev and pull, IMO
Reread my post, as I first posted it , it was confusing. mike
Re: How much cam advance is too much? [Re: Sport440] #931145
02/18/11 01:47 AM
02/18/11 01:47 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
It all really depends on the engine and what you want to do with it. Now for starters, throw out the mindset that advancing the cam increases bottom end and retarding it increases top end. While this tends to be true, it's not always the case(at least it's not that simple). The cam is going to produce the most power at a specific installed point. Case in point. The shop I used to work for had built a 468" pontiac big block. The cam had been installed straight up (110 ICL). When dynoed, this engine produced approximately 525-535 hp at its peak. Due to the shop installing the motor not understanding that the distributor needed to be engaged in the oil pump drive BEFORE cranking down on the distributor hold down, the drive split at the oil pump and the engine lost oil pressure. Long story short, the engine came back out and was sent back to us. This time I assembled the motor and installed the cam at 107 ICL with no other changes. Hp was up in the 560 range now and there was more bottom end power AND more top end power.
My point is, the engine liked the cam being advanced those 3 degrees and while it did increase the bottom end, it also increased the top end and the peak numbers. Obviously the only way to know exactly where it needs to be is to have a dyno and be willing to move the cam around or to be much smarter with numbers than I am and/or rely on God giving you a little insight on what that particular engine wants the cam installed at.
Or to answer your question simply, there's too much advance when the engine starts dropping power ...
Re: How much cam advance is too much? [Re: dodgeboy11] #931146
02/18/11 09:55 AM
02/18/11 09:55 AM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Well I found out the hard way that a car with exhaust manifolds really does not like a cam advanced too far. Had the F.A.S.T. motor out of the AAR "freshened" by a shop, had them port a 71 intake, then installed in my 500lb lighter duster to go out an run 12.00's when the AAR was running 11.6's pretty consistantly. After chasing the issue for a few months found he had installed the cam @ 101.5 when it should have been in @ 109, cut @ 113. Moved the cam, car picked up over 5 tenths and almost 7mph. Still dealing with other headaches still.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
