6-bbl idle solenoid bracket? #930244
02/16/11 09:46 AM
02/16/11 09:46 AM
Stuart, FL
Grassosgarage Offline OP
Stuart, FL
where can I find the correct bracket for a 6-bbl idle solenoid? Year-one shows for 4bbl only...
'70 Cuda 440/auto
'70 Duster 340/4sp project
'70 Satellite convert 318 survivor
Re: 6-bbl idle solenoid bracket? [Re: Grassosgarage] #930245
02/16/11 10:14 AM
02/16/11 10:14 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
it's spot welded to the side of the solenoid body
Re: 6-bbl idle solenoid bracket? [Re: Grassosgarage] #930246
02/16/11 12:15 PM
02/16/11 12:15 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I agree that it is part of the solenoid. See attached photo.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 6-bbl idle solenoid bracket? [Re: 70gtx440dana] #930247
02/16/11 12:19 PM
02/16/11 12:19 PM
i think he might asking about the solenoid harness bracket. If so, Frank Badalson would have that.
Re: 6-bbl idle solenoid bracket? [Re: ] #930248
02/16/11 04:19 PM
02/16/11 04:19 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
What motor? The 340 had a seperate bracket that bolted between the carbs.Those were reproduced at one time
NS1AAR
