Super Slant Six #928833
02/14/11 05:32 PM
02/14/11 05:32 PM
NY
MoparGary7272 Offline OP
NY
I'm in the process of taking out my blown slant six from my 72 duster. I just acquired a Super Slant Six from a 77 Aspen... what do i need to convert to have an "easy" swap?? its only temporary until i get the 340 done, but what else besides the wiring harness ( to omit POINTS!!) would i need? thanks
Re: Super Slant Six [Re: MoparGary7272] #928834
02/14/11 05:39 PM
02/14/11 05:39 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
Nothing, rip out the dead one and slam the Super Six in!!
Yankin' and Slammin' a Mopar Super Slant Six!!
There's even a super easy way to turn the factory Mopar magnetic pickup dizzy into an HEI using junkyard schtuff, but I don't have a handy-dandy link-o-rama.
Re: Super Slant Six [Re: rabid scott] #928835
02/14/11 05:57 PM
02/14/11 05:57 PM
the two threaded bosses you see in the pic are perfect for pulling it
Re: Super Slant Six [Re: RapidRobert] #928836
02/14/11 06:10 PM
02/14/11 06:10 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
Oh, if you have a voodoo juicebox you'll need the Super Six specification kickdown linkage or convert over to a cable kickdown.
Almost forgot about that!
Re: Super Slant Six [Re: rabid scott] #928837
03/03/11 06:33 PM
03/03/11 06:33 PM
NY
NY
a little late, but thank you !! just making sure i knew what to prepare myself for when dropping it in.. its getting warmer out and im getting more excited to rebuild the 340 hahaha
Re: Super Slant Six [Re: MoparGary7272] #928838
03/04/11 12:12 AM
03/04/11 12:12 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
As stated, you must have the Super Six kick down linkage. I'd swap the tranny in from the Aspen or donor as well; might be a lockup trans and get a little better mileage.
Re: Super Slant Six [Re: Sixpak] #928839
04/14/11 12:13 PM
04/14/11 12:13 PM
NY
NY
Unfortunately the trans was a four speed and the guy I got the motor from took that.. on a better note... my buddy and I swapped the motors in 3 hours but are stuck with the wiring harness issue.... what exactly do I need to replace on the standard points setup so that I can switch out on the plug by the firewall...I have the four prong ballast and the silver box on the inner fender... finding an electronic setup for a 72 was harder than I thought ... is there anything im missing here?
Re: Super Slant Six [Re: MoparGary7272] #928840
04/14/11 12:26 PM
04/14/11 12:26 PM
USA
b54406barrel Offline
USA
If you have the electronic distributor, here's a link to wire it. If you're trying to convert your point dist. to electronic, I can't help you there.
http://www.allpar.com/fix/electronic-ignition.html
Re: Super Slant Six [Re: b54406barrel] #928841
04/14/11 12:48 PM
04/14/11 12:48 PM
NY
NY
Thanks a bunch! That's basicly what I was looking for to guide this swap! ! Thanks again
Re: Super Slant Six [Re: MoparGary7272] #928842
04/14/11 12:57 PM
04/14/11 12:57 PM
Nevada
Darter6 Offline
Darter6  Offline
Nevada
When you yank that super six for the 340, Go to SlantSix.org. Guys over there are always looking for super six stuff. I got $50 bucks just for the iron 2 bbl intake. The exhaust manifold has a larger outlet and flange than a standard 1 bbl engine too.
Re: Super Slant Six [Re: Darter6] #928843
04/14/11 01:18 PM
04/14/11 01:18 PM
NY
NY
Will do;) yea I left the f body exhaust setup on it (2") which bends over to the passenger side ..slapped a glass pack on it and called it a day Haha. Hopefully the 340 is done by mid summer
Re: Super Slant Six [Re: MoparGary7272] #928844
04/14/11 01:22 PM
04/14/11 01:22 PM
USA
USA
No problem, I just did a dist. swap last weekend.
Re: Super Slant Six [Re: Darter6] #928845
04/16/11 07:24 AM
04/16/11 07:24 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
No, it does not, but the manifolds are always in demand because they crack a lot.
