what carb #928633
02/14/11 11:03 AM
02/14/11 11:03 AM
United states wisconsin
bigblockbryan Offline OP
okay i wanna now what carb you guys would recommand for my set up i now we have been over how much junk my elderbrock 750 is so heres your guys chance lol i have a 440 with speed pro pistons that are 10.1 comp 346 heads elderbrock performer intake and a 484 comp cam im ordering tti 2.5 inch dual exaust too i just wanna get the thing right put some miles on the pavement and not on my tools this year alotta guys said my hetting stock outta the box eddy is to lean so can you reccomand a good carb that would be good outta the box
Re: what carb [Re: bigblockbryan] #928634
02/14/11 11:33 AM
02/14/11 11:33 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
That cam probably doesn't pull a ton of vacuum. It's operating range is like 2400-6200. I'm guessing it would like headers, 3200+ stall and 3.91 gears. I'd probably use a 750DP. I guess you could ge bigger if you plan on all out passes at the track.
Coming soon!!!!
Re: what carb [Re: Mr.Yuck] #928635
02/14/11 11:41 AM
02/14/11 11:41 AM
yea its got a 4 speed and its more of street car with the occasional pass im running mainfolds is that gonna make a diffrence. On how it runs or just wont have as much power right now its gota miss under load its not timing i timed the hell outta it last year so i think its fuel. trying not sink awhole lotta cash into this year cause im in the process of building a shop so i have my own place to work on my mopars
Re: what carb [Re: bigblockbryan] #928636
02/14/11 12:00 PM
02/14/11 12:00 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
w/o the headers you're probably leaving 20hp on the table. If you have a miss under load it's more likey to be something like a bad wire, coil, plug...maybe even a bad valve spring. Have you done a leak down or compression check? Do you know what cylinder it is?
Coming soon!!!!
Re: what carb [Re: Mr.Yuck] #928637
02/14/11 01:16 PM
02/14/11 01:16 PM
no idea what cylinder cause it really only happens once your on it if you stay bottom seemed to run okay as soon as youd jump on it would just miss. Really bad every one told it was the timing cause i timed it by ear so i bought a light i was off 2 degrees so i set it and it still had the miss. The thing was the motor ran great when i parked it and then i had a problem were my oil pressure dropped due to a leaky fuel pump wich wiped out the bearings so i bought new bearings got the crank ground then went from a a resto mod mopar cam to a comp 484 was told my valve springs were good up to a 509 none of the springs are broke cant really do much with the engine untill the snow and salt get off the road in wi. how do i do leak down test? ill compression test it when i pull it in the shop after i do the exaust maybe ill go buy a new coil wires the wires and coil are about 6 years old but really theres probably less then 200 miles on it all
Re: what carb [Re: bigblockbryan] #928638
02/14/11 01:23 PM
02/14/11 01:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Check and see how many vots you have at the ballast, coil and battery, Easy to do w/ an automatic but not sure how you are gouing to do a load test w/ a stick. I had an issue like yours, ran killer out of gear, checked timing checked carb signal bla bla bla, it would run like doo doo and die once you dropped it into gear. Turned out I had a bad ballast, it was dropping the power to the coil way down.
Re: what carb [Re: bigblockbryan] #928639
02/14/11 06:23 PM
02/14/11 06:23 PM
a 750 vac sec (3310) or maybe one of the holley clones that has a better street part throttle metering system but the basic holley above is simple/dependable/foolproof.
Re: what carb [Re: RapidRobert] #928640
02/15/11 03:39 PM
02/15/11 03:39 PM
would a holley 750 dp work good too cause a friend of mine has one he had on is 500 horse camaro he might consider selling me hes gonna let me bolt it on this spring and try it out
Re: what carb [Re: bigblockbryan] #928641
02/15/11 05:26 PM
02/15/11 05:26 PM
Perfect!
