ID the carter AFB 3615S #926399
02/11/11 12:50 PM
02/11/11 12:50 PM
O
Oldpar Offline OP
Oldpar  Offline OP
O
It is to go on my 1965 413. I need to know what the "cfm" is? Thanks Rich
Re: ID the carter AFB 3615S [Re: Oldpar] #926400
02/11/11 01:32 PM
02/11/11 01:32 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
If its the same as a 383 (likely) its about 500-525 cfm. Makes for a good half of a dual quad.
Those have the fully mechanical rear with no accel pump.
Re: ID the carter AFB 3615S [Re: RemCharger] #926401
02/11/11 03:37 PM
02/11/11 03:37 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Would you clarify "no accel pump",AFB or AVS has to have one.
Re: ID the carter AFB 3615S [Re: Oldpar] #926402
02/11/11 06:01 PM
02/11/11 06:01 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
That carb number is for a 1964 413. It would be an AFB. Don't know the CFM.
