{{{ VALIANT UPDATE - DASH & GAUGES }}} #926147
02/11/11 11:39 AM
02/11/11 11:39 AM
Lehigh Acres, Florida
rickstershemi Offline OP
Got my aluminum dash bezel made up....Dave @ Ultimate Motorsports did the work and fit & finish is perfect....had them make a duplicate of the original w/new gauge layout....Thanks Dave
Thinking of polishing the perimeter and powder-coating the insert w/a satin alum finish & then gloss the whole piece
The gauges are all Marshall, I went with their Mopar Muscle Car design and they rock. The through the dial lighting is incredible and also got the LED dimmer....
http://www.youtube.com/watch?v=yDjKS1RRsx0
Thinking of putting the Oil Pressure & Water Temp gauges in cups mounted in front of the dash speaker (old school)
Original Bezel
Rickster
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: rickstershemi] #926148
02/11/11 11:53 AM
02/11/11 11:53 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Those are pretty neat gauges rick.
How do they cost relative to what's typically out there?
Can the LED color be changed to something else?
I prefer something in a red/blue.
The ones you got look good.
I would definitely powdercoat the bezel black and then wirebrush the perimeter or something.
It pains me to see this car almost complete when I STILL havent even chosen what car I want to use for my motor and trans. Especially since I started building my engine before you even bought this car.
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: rickstershemi] #926149
02/11/11 11:57 AM
02/11/11 11:57 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Lookin' good, Rick. I'm gonna have to come down and go for a ride in that bad boy.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: rickstershemi] #926150
02/11/11 12:05 PM
02/11/11 12:05 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
I think it is a cool design but that big old weld around the perimeter keeps catching my eye. I would personally have to do something to tone that down. Either grind it to a nice fillet or fill it with body filler to get a nice smooth radius. As far as color, what about silver for the outside panels and paint the center panel the same blue as the dash.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: bigsbigelow] #926151
02/11/11 12:07 PM
02/11/11 12:07 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Lookin very nice, gonna be an awesome car when its done
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: 69B3GT] #926152
02/11/11 12:24 PM
02/11/11 12:24 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Looks nice,
Id also take a sanding roll on a dremmel, and knock that weld to a nice radious. Shouldnt be too tough, and the thing will still have its brushed look.
Kasey
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: rickstershemi] #926153
02/11/11 01:34 PM
02/11/11 01:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lookin good...............I made a similar one for my dart except it`s flat and filled it w/VDO gauges. WAY nicer than the stock plastic stuff.
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: Moparnut426] #926154
02/11/11 02:04 PM
02/11/11 02:04 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Looks nice,
Id also take a sanding roll on a dremmel, and knock that weld to a nice radius. Shouldnt be too tough, and the thing will still have its brushed look.
Kasey
If you were closer to me, I'd prep it and shoot it for ya with automotive paint in the color of your choice. PM me if you're interested and you'll be up near Tampa soon.
Gauges look real nice!
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: Thumperdart] #926155
02/11/11 02:25 PM
02/11/11 02:25 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: rickstershemi] #926156
02/11/11 02:53 PM
02/11/11 02:53 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
the pics are not working for me?
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: I_bleed_MOPAR] #926157
02/11/11 03:31 PM
02/11/11 03:31 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Gauges are cool, but that weld should have been on the back side
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: rickstershemi] #926158
02/11/11 07:08 PM
02/11/11 07:08 PM
mass
K
kotacars Offline
kotacars  Offline
K
mass
The gauges are all Marshall, I went with their Mopar Muscle Car design and they rock. The through the dial lighting is incredible and also got the LED dimmer.... :thumb :
I will not sugar coat it that looks like POS what did he charge you for that. If you want to see some nice gauge inserts send me your email.
Original Bezel
Rickster
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: kotacars] #926159
02/11/11 07:29 PM
02/11/11 07:29 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
The cluster looks good to me. I would grind the welds and and powder coat the housing chrome. It's moving right along for you now. Let's hear the new engine come alive.
6.50 @105.26
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: Kindafast] #926160
02/11/11 08:38 PM
02/11/11 08:38 PM
Just walked in the door from a long day on the job......thanks for all the comments.....I actually planned on cleaning up the welds and thanks Dave for the offer
I'm still leaning towards polishing up the perimeter and doing the center in more of a satin finish.....the gauges are amazing and for all 6 including the dimmer & hall effect sensor for the speedo cost $435 to my door.....I hooked up the speedo and as stated before the through the face lighting is unbelievable....has a choice of either white or amber.....I'm going to install a single pole dbl throw switch so I can change the color at will
Hope to fire up the 408 in the near future....still have headers and a ton of other chit to buy c'mon lotto
Rickster
Re: {{{ VALIANT UPDATE - DASH & GAUGES }}} [Re: I_bleed_MOPAR] #926161
02/12/11 12:03 AM
02/12/11 12:03 AM
Tim
When it's done you're more than welcome Tim
Rickster
