Page 1 of 5 1 2 3 4 5
Third generation Dakota's #925025
02/09/11 10:34 PM
02/09/11 10:34 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Building a 97' Dakota. Would like to see some pics if anyone has one or just has pics.
Leon
Re: Third generation Dakota's [Re: Leon441] #925026
02/09/11 10:45 PM
02/09/11 10:45 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
hi. what are you looking for? I've been through my truck pretty throughouly, and can answer lots of questions!
check out www.dakota-durango.com too.
lotta guys have their R/Ts well into the 11s and 12s, a few in the 10s, and at least 1 guy trying to get into the 9s.
http://www.youtube.com/v/5M1iBf2wjEw
http://www.youtube.com/v/sgkOx73GIw4
http://www.youtube.com/v/zUJ2or1zBtU
here a link to a ton of pics of my truck in work
http://s24.photobucket.com/albums/c6/filbert383/Dakota%20Engine%20swap/
**Photobucket sucks**
Re: Third generation Dakota's [Re: Leon441] #925027
02/09/11 11:27 PM
02/09/11 11:27 PM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
Do not check out dakota-durango. Its a waste of life. There are a few interesting setups on dakotart.com
2000 dakota 418 magnum paxton novi 2k T56
Re: Third generation Dakota's [Re: Sick 660r] #925028
02/10/11 12:32 AM
02/10/11 12:32 AM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
I get the feeling Leon isn't looking for R/T's with Hotchkiss suspension kits and billet battery covers.
Re: Third generation Dakota's [Re: Devilbrad] #925029
02/10/11 12:35 AM
02/10/11 12:35 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
probably more like coil over strut and four link
Re: Third generation Dakota's [Re: Devilbrad] #925030
02/10/11 12:36 AM
02/10/11 12:36 AM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
Here are some class racing Dakotas.
Re: Third generation Dakota's [Re: Devilbrad] #925031
02/10/11 12:39 AM
02/10/11 12:39 AM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
I still stand by my opinion that the Gen 2's are better looking.
Re: Third generation Dakota's [Re: Devilbrad] #925032
02/10/11 12:44 AM
02/10/11 12:44 AM
jamesc Offline
jamesc  Offline
naa...lowrider
Re: Third generation Dakota's [Re: jamesc] #925033
02/10/11 12:47 AM
02/10/11 12:47 AM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
Re: Third generation Dakota's [Re: Devilbrad] #925034
02/10/11 12:47 AM
02/10/11 12:47 AM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
Does anybody have any info on that black stocker.That looks like mines little brother.Great looking truck.Would like to know frontend setup.
Re: Third generation Dakota's [Re: 8secDart] #925035
02/10/11 12:50 AM
02/10/11 12:50 AM
jamesc Offline
jamesc  Offline
i thought you were selling the dakota Lenny
Re: Third generation Dakota's [Re: 8secDart] #925036
02/10/11 12:50 AM
02/10/11 12:50 AM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
The Gen 2? That's my friend Jennifer McCormack's truck. What do you want to know, I can find out.
Re: Third generation Dakota's [Re: Devilbrad] #925037
02/10/11 01:19 AM
02/10/11 01:19 AM
8secDart Offline
8secDart  Offline
I'am keeping the old rag,LOL.It's all done now.Time to let it eat.
Yes the black stocker GEN 2.
See if he has a drop spindle or what spring he has.It sets low in the front.I got mine that low but just looking at a different way.His looks like it works really well.You can PM me if you don't want to put the info on here.Thanks Lenny
Re: Third generation Dakota's [Re: 8secDart] #925038
02/10/11 01:23 AM
02/10/11 01:23 AM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
She. Pretty sure her truck has dropped spindles and Moroso track springs for a Chevelle, that's what most Gen 2 stockers use. I was planning on fabbing control arms and using QA1 shocks for a Chevelle/Nova application with the tapered springs that fit in the frame spring pocket, but have the adjustable collar on bottom of spring. And possibly MII spindles to take advantage of the aftermarket brake choices.
Edit: Just heard back from Jennifer, truck has V6 Dakota springs and Afco shocks with dropped spindles.
Re: Third generation Dakota's [Re: Devilbrad] #925039
02/10/11 01:52 AM
02/10/11 01:52 AM
8secDart Offline
8secDart  Offline
Thanks for the info
I got tublar lower with the drop pocket and stock uppers.I still had to cut a 1/4 round out of a 6cyl spring to get it down.The upper ball jouint is at more of an angle than I like.It's not in a bind but just not perfect.
PS,sorry to hijack the thread Leon,LOL
Re: Third generation Dakota's [Re: Devilbrad] #925040
02/10/11 09:32 AM
02/10/11 09:32 AM
Georgia
CopperDodge Offline
CopperDodge  Offline
Georgia
Find out what else she is doing to leave that hard. Trans brake? What all did she take off the front end? I want my tires up in the air like that....
Re: Third generation Dakota's [Re: CopperDodge] #925041
02/10/11 05:11 PM
02/10/11 05:11 PM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
X2
More specs on the shocks as well.
Re: Third generation Dakota's [Re: CopperDodge] #925042
02/10/11 05:23 PM
02/10/11 05:23 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
This is a customer truck I am doing. They like generation 3 as they are RT fanatics. Curious about drop spindles for this application. Don't like the lower control arm with the altered spring pocket because it changes the geometry in an unfavorable way. I'm hearing some big prices for the spindles though.
The other thing is lightweight lift off hoods that actually fit stock trucks. Pics of front frames as to answer where is it safe to cut weight. Just would like to see some ideas. Already got some plans just would like the added security of seeing what was done in the past.
It's not a backhalf 4-link or ladder bar. But, the framerails are very much modified with caltrac leafs and caltracs. An awesome set of shocks. Trimed down Dana 60 with some nice internals. Truck should turn out nice Holeshot Star wheels true 10.5's . I had nothing to do with the engine so we will just have to see how it runs.
Leon
Re: Third generation Dakota's [Re: Leon441] #925043
02/10/11 05:37 PM
02/10/11 05:37 PM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
I have more if you need anything else
Re: Third generation Dakota's [Re: Leon441] #925044
02/10/11 05:39 PM
02/10/11 05:39 PM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
Leon
I dont know of any drop spindles or lift off hoods.
