Leakdown testers and how to use...... #922875
02/07/11 04:56 AM
02/07/11 04:56 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I have a problem with oil consumption and smoke in the 493 in my 70 Charger. The diagnosis has been a real puzzler, and I think that a leakdown test may be the last thing I can do before pulling the motor for a teardown and inspection.
1974 440 block, bored .030
Eagle 4.15 crank, Manley rods, Ross pistons
Edelbrock 88cc heads, unported
292/509 cam Eddy Perf RPM intake, BG 850 VS TTI 2" headers, 2.5 exhaust
2500 miles on rebuild.
The engine ran great for a few years, but over the last 3 it has developed the following problem: I can cruise around on the primaries just fine, but once I step into the secondaries, white smoke rolls out then clears away. When I slow down, the smoke returns.
I had a 292/509 cam in the motor when I first assembled it, then switched to a Comp 285 XE. The Comp ran great until it wiped a lobe. I slipped in another Comp on warranty and it ran great again for 2 years until it wiped THAT cam. Once again, only one lobe went bad. I took the oil pump apart to find debris in the rotors, so I replaced the pump. Over the years I have chased my tail trying to eliminate this smoke problem. I have ran the car with and without a PCV, checked the intake for squareness against the heads intake surface, replaced the valley pan twice, once with the paper gaskets and once without, replaced the valve stem seals, did numerous compression checks and this problem still remains. The last comp check was consistant with the others.... the highest was 192 and the lowest was 180. A 6% spread? Isnt that about the best you can hope for?
I have read the plugs...They get black all around the insulator after awhile. I had the heads off, all the exhaust valves were tan colored. ZERO vacuum leaks. Zero coolant loss. Plenty of power, but not as much as when it didnt smoke.
This is where the leakdown tester sounds appealing. I have never seen one up close, but from what I have read, they can tell alot about whats happening inside the motor. What is considered acceptable leakage and how is it determined? When I replaced the valvestem seals, I had to pressurize each hole while I had the springs off. You could hear a steady hiss. Given time, any cylinder will totally lose pressure, right? The rings are not a suction cup type of seal.
I know that with the 2 bad cams I need to pull the engine apart for a full teardown and cleaning. I am just baffled as to HOW an engine with such good compression numbers can smoke like this one does. Suggestions?
Re: Leakdown testers and how to use...... [Re: Kern Dog] #922876
02/07/11 11:51 AM
02/07/11 11:51 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
That does suck man , but maybe the oil controll rings are not working correctly or somehow got severly coaked up ?
were there any scrathces in the bore walls ? maybe the motor has low tension rings by mistake ( boxed wrong )
Try some retore engine fix in a can if you want to see if it helps .
worth a shot you are going to have to tear it down any way sounds like .
1969 Dodge Charger 1969 Dodge Superbee
Re: Leakdown testers and how to use...... [Re: cjs69mope] #922877
02/07/11 02:42 PM
02/07/11 02:42 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
My is the rings, pistons and or bores are probably shot. If the motor was not tore down after you lost the first cam, most likely you have metal embedded in the skirts.
Did you wipe the same lobe on both cam failures?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Leakdown testers and how to use...... [Re: Von] #922878
02/07/11 03:18 PM
02/07/11 03:18 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Different lobes went bad. I considered the tight lifter bore possibility, but they all rotate nicely. I called Hensley Performance. They are the guys I got the stroked crank and rotating assembly. They stated my order had standard oil rings. When I had the heads off some time ago the cylinders looked okay to the naked eye, but who really knows without a teardown.
Re: Leakdown testers and how to use...... [Re: Kern Dog] #922879
02/07/11 04:06 PM
02/07/11 04:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A leakdown test will only show the sealing quality of the compression rings, you could have near zero leakdown and still have bad oil control rings.
Re: Leakdown testers and how to use...... [Re: John_Kunkel] #922880
02/07/11 06:16 PM
02/07/11 06:16 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Yeah... I was thinking that too. Son of beech.
Re: Leakdown testers and how to use...... [Re: Kern Dog] #922881
02/07/11 09:40 PM
02/07/11 09:40 PM
I WOULD do the leakdown (get each cyl to TDC & plug in the air) to see what you got & a rering would be a solution but w the debris prob as said you might have to bite the bullet & dissassemble all the way & see what you see. "A Good visual" id's/solves alot of probs. Myself I'd leave the eng in place & pull the pistons/rods/check the cyls/R&R the rings/bearings (not hard to do) & not sweat the debris . Holler how it turns out EDIT that's TDC compression
