Re: 70 roadrunner 383 or 440 ? [Re: stumpy] #922402
02/06/11 10:05 PM
02/06/11 10:05 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i don't know. i can appreciate both the 'gearhead' side and the 'correct zip tie' side, but i honestly think us guys in the middle would not see much of a difference, performance wise, between a 440 and a 383. except for when it comes to finding and paying for one.
Re: 70 roadrunner 383 or 440 ? [Re: mikemee1331] #922403
02/06/11 10:14 PM
02/06/11 10:14 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Well, there's a LOT of talk about stroked 383's..............
Re: 70 roadrunner 383 or 440 ? [Re: Yancy Derringer] #922404
02/07/11 01:01 AM
02/07/11 01:01 AM
Scituate, RI
SkynyrdTim Offline
SkynyrdTim  Offline
Scituate, RI
I'd never take a 383 over a 440. You're giving up at least 40 hp and a probably a good 60 ft-lbs of torque. If the cost is the same, why take less hp and torque? And believe me, there is a BIG difference between the two engines. A properly tuned 440 can be scary fast. Hard to make a 383 that fast. Just my take on it.
Re: 70 roadrunner 383 or 440 ? [Re: 70Runnerdude] #922405
02/07/11 01:35 AM
02/07/11 01:35 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
The answer lies in my illiterate username
Re: 70 roadrunner 383 or 440 ? [Re: forphorty] #922406
02/07/11 02:08 AM
02/07/11 02:08 AM
Kansas
BEINGmeISaCRIME Offline
Kansas
I read this quote somewhere, not sure where exactly but it went something like this..
A Body - Small blocks only
B Body - Go big or go home
E Body - Flip a coin
Re: 70 roadrunner 383 or 440 ? [Re: BEINGmeISaCRIME] #922407
02/07/11 09:59 AM
02/07/11 09:59 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
i thought 69 1/2 was first year for a 440 in a rr. if you are building a pretty much stock street car motor, meaning adding headers and a intake either the 383 or the 440 will work just fine. you will not be using all the power that either of these motors will produce. you are driving it and once in awhile burning the tires. if you think that you need a little more power build either one. i like the 383, doing it over i would have used our 426 street wedge.
Re: 70 roadrunner 383 or 440 ? [Re: 70Runnerdude] #922408
02/07/11 10:42 AM
02/07/11 10:42 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
440, same cost (except for up-front cost) but same parts net much more power and torque. Go big or stay home
Coming soon!!!!
Re: 70 roadrunner 383 or 440 ? [Re: Mr.Yuck] #922409
02/07/11 11:17 AM
02/07/11 11:17 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I'd go with the 383, for me it's just iconic to the name plate.
Re: 70 roadrunner 383 or 440 ? [Re: Montclaire] #922410
02/07/11 11:39 AM
02/07/11 11:39 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
I would build a high compression 383 with good parts and ported edelbrock heads so you can stomp the crap out of most stock and maybe stock 426 cars on the street and make them all mad....
use a good cam to spin it over 6grand and runn the hell out of it !
1969 Dodge Charger 1969 Dodge Superbee
Re: 70 roadrunner 383 or 440 ? [Re: cjs69mope] #922411
02/07/11 12:31 PM
02/07/11 12:31 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I'd never put a RB motor in an original B motor car. Keep a B motor in it but not a 383. A 400 block out to 511 inches is the way to go.
Re: 70 roadrunner 383 or 440 ? [Re: mikemee1331] #922412
02/07/11 02:27 PM
02/07/11 02:27 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
This isn't rocket science; the 383 and 440 are the same basic engine using the same heads, ect. If you were to build your engine to a nice 1hp per cu then the 440 is going to have 57 more hp all things being equal and that is too much to ignore.
I'll put it another way: you'll give up approximately 15 percent going with the 383.
So, if the choice is between a bone stock 383 or a bone stock 440 and correctness isn't an issue then the choice to go with a 440 is a no-brainer......BUT, If I had an original 383 RR, I would build a 383 or 400 stroker to retain the B engine but with an RB kick.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
