Page 1 of 5 1 2 3 4 5
Small block race block #921974
02/06/11 01:05 AM
02/06/11 01:05 AM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
Whats the deal with the xr1 blocks? Why are they not being used? Does anybody run one?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Small block race block [Re: 1967dartgt] #921975
02/06/11 12:36 PM
02/06/11 12:36 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
who says they're arent being used?
Re: Small block race block [Re: theclutcher] #921976
02/06/11 12:40 PM
02/06/11 12:40 PM
Hilltown Pa
Hilltown Pa
Well then who has one and whats the combo?
Re: Small block race block [Re: 1967dartgt] #921977
02/06/11 12:45 PM
02/06/11 12:45 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
I'm sure they will post.
Looking for one?
Re: Small block race block [Re: theclutcher] #921978
02/06/11 01:21 PM
02/06/11 01:21 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
9.610" deck
50mm cam tunnel
340 mains
Wedge bolt pattern
225 lbs with 4.150 bores
Re: Small block race block [Re: S/ST 3040] #921979
02/06/11 02:13 PM
02/06/11 02:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Vic... looks like they damn near missed the boss area
on the upper head bolt holes on the first and third holes
looks like a nice block.... also what are the holes
above each lifter bores... maybe oil holes(oil letter
inners )
Re: Small block race block [Re: MR_P_BODY] #921980
02/06/11 02:45 PM
02/06/11 02:45 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
inners )
There is a reason those holes are offset, I just can't remember why, LOL It was in another thread. As for the holes over the bushings, I'm assuming they are access holes to drill oiling holes in the bushings after they are pressed in.
Re: Small block race block [Re: MR_P_BODY] #921981
02/06/11 02:50 PM
02/06/11 02:50 PM
Q
Quicktree Offline
Quicktree  Offline
Q
inners )
yea no kidding, I don't know a thing about block castings but why is it so hard to build a block with out core shift and some of the other known problems? you would think this day and age they could correct those issues. not saying this block has them just curious.
Re: Small block race block [Re: MR_P_BODY] #921982
02/06/11 02:54 PM
02/06/11 02:54 PM
S/ST 3040 Offline
S/ST 3040  Offline
inners )
Mike, It's my belief, the XR blocks were initially cast soley for P-7 heads. (XR-2)
On the XR-2 version, the bolt holes are located in the center of the bosses.
Notice the extra head bolt boss at the rear of the block. (2nd picture)
P-7 heads use 20 studs.
I asked Kent about machining the XR to accept the P-5 HEMI. I think it's possible
but, doubt it will happen. 430"+ P-5 HEMI??!!
Holes drilled to the inside of the lifter bores are pilot holes to the oil feed. Then the
pre-drilled bushings were pressed in and honed. Just happens to be the way this
particular machinist chose to do it.
Re: Small block race block [Re: Devilbrad] #921983
02/06/11 02:57 PM
02/06/11 02:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Why not drill the bushings before you press them in...
thats how mine were done
Re: Small block race block [Re: S/ST 3040] #921984
02/06/11 03:04 PM
02/06/11 03:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Got ya...
Re: Small block race block [Re: S/ST 3040] #921985
02/06/11 04:19 PM
02/06/11 04:19 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Looking good Vic.
How many cubes?
Re: Small block race block [Re: theclutcher] #921986
02/06/11 04:21 PM
02/06/11 04:21 PM
S/ST 3040 Offline
S/ST 3040  Offline
340!
Re: Small block race block [Re: S/ST 3040] #921987
02/06/11 04:23 PM
02/06/11 04:23 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Another Screamer!!!
Need to find a suitable rpm greamlin.
What crank with the 4.150 bore?
Re: Small block race block [Re: theclutcher] #921988
02/06/11 04:26 PM
02/06/11 04:26 PM
S/ST 3040 Offline
S/ST 3040  Offline
OK......
I was kidding. 447" with W-8s
4.155" x 4.125"
Re: Small block race block [Re: S/ST 3040] #921989
02/06/11 04:31 PM
02/06/11 04:31 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
340!
You got a pic of the block from the bellhousing area?
Re: Small block race block [Re: S/ST 3040] #921990
02/06/11 04:32 PM
02/06/11 04:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
OK......
4.155" x 4.125"
Gonna run one of them big blocks hidden in a small
block cover.... cool
Re: Small block race block [Re: S/ST 3040] #921991
02/06/11 04:38 PM
02/06/11 04:38 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Ya know how to pull my strings you dawg.
I'm a sucker for RPM...
elaborate on your W8's if you can.
Any numbers?
Callies crank?
Want to compare to some castings here.
oops getting off topic... sorry
Re: Small block race block [Re: S/ST 3040] #921992
02/06/11 07:01 PM
02/06/11 07:01 PM
SoCal
Brian Hafliger Online content
Brian Hafliger  Online Content
SoCal
OK......
4.155" x 4.125"
Looks like rpm is still in the picture!!
Brian Hafliger
Re: Small block race block [Re: theclutcher] #921993
02/06/11 07:56 PM
02/06/11 07:56 PM
Hilltown Pa
Hilltown Pa
Looking for one?
I might be...
Just thinking about next engine and was thinking a big cube W-8 motor would run good.Thinking 4.185x4.25 and having a 468 cuin small block.
