Small block race block
#921974
02/06/11 01:05 AM
02/06/11 01:05 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Whats the deal with the xr1 blocks? Why are they not being used? Does anybody run one?
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: Small block race block
[Re: theclutcher]
#921976
02/06/11 12:40 PM
02/06/11 12:40 PM
1967dartgt
Hilltown Pa
Well then who has one and whats the combo?
[Re: 1967dartgt]
#921977
02/06/11 12:45 PM
02/06/11 12:45 PM
Posts: 2,172 Ohio
theclutcher
Ohio
I'm sure they will post. Looking for one?
[Re: S/ST 3040]
#921979
02/06/11 02:13 PM
02/06/11 02:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Vic... looks like they damn near missed the boss area on the upper head bolt holes on the first and third holes looks like a nice block.... also what are the holes above each lifter bores... maybe oil holes(oil letter inners )
[Re: MR_P_BODY]
#921980
02/06/11 02:45 PM
02/06/11 02:45 PM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
There is a reason those holes are offset, I just can't remember why, LOL It was in another thread. As for the holes over the bushings, I'm assuming they are access holes to drill oiling holes in the bushings after they are pressed in.
[Re: MR_P_BODY]
#921981
02/06/11 02:50 PM
02/06/11 02:50 PM
Quicktree
yea no kidding, I don't know a thing about block castings but why is it so hard to build a block with out core shift and some of the other known problems? you would think this day and age they could correct those issues. not saying this block has them just curious.
[Re: MR_P_BODY]
#921982
02/06/11 02:54 PM
02/06/11 02:54 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Mike, It's my belief, the XR blocks were initially cast soley for P-7 heads. (XR-2) On the XR-2 version, the bolt holes are located in the center of the bosses. Notice the extra head bolt boss at the rear of the block. (2nd picture) P-7 heads use 20 studs.
I asked Kent about machining the XR to accept the P-5 HEMI. I think it's possible but, doubt it will happen. 430"+ P-5 HEMI??!!
Holes drilled to the inside of the lifter bores are pilot holes to the oil feed. Then the pre-drilled bushings were pressed in and honed. Just happens to be the way this particular machinist chose to do it.
[Re: S/ST 3040]
#921987
02/06/11 04:23 PM
02/06/11 04:23 PM
Posts: 2,172 Ohio
theclutcher
Ohio
Another Screamer!!! Need to find a suitable rpm greamlin. What crank with the 4.150 bore?
[Re: S/ST 3040]
#921989
02/06/11 04:31 PM
02/06/11 04:31 PM
Posts: 3,395 Pa
Hot 340
Pa
340!
You got a pic of the block from the bellhousing area?
[Re: S/ST 3040]
#921990
02/06/11 04:32 PM
02/06/11 04:32 PM
MR_P_BODY
OK......
I was kidding. 447" with W-8s
4.155" x 4.125"
Gonna run one of them big blocks hidden in a small block cover.... cool
[Re: S/ST 3040]
#921991
02/06/11 04:38 PM
02/06/11 04:38 PM
Posts: 2,172 Ohio
theclutcher
Ohio
Ya know how to pull my strings you dawg. I'm a sucker for RPM... elaborate on your W8's if you can. Any numbers? Callies crank? Want to compare to some castings here. oops getting off topic... sorry
