Hemi Bellhousing and starter question #920677
02/04/11 12:13 AM
02/04/11 12:13 AM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
Can you use a stock gear reduction starter on a hemi with a 2892262 11 inch cast iron bellhousing and stock exhaust manifolds? is there enough clearance??
Re: Hemi Bellhousing and starter question [Re: hemi67] #920678
02/04/11 03:07 AM
02/04/11 03:07 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
No it will not fit.
I personally thought it would, however it does not. The starter and exhaust manifold want the same spot. NO GO.
I would up with a Rob Mc starter and it works great..
Re: Hemi Bellhousing and starter question [Re: sthemi] #920679
02/04/11 03:08 AM
02/04/11 03:08 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
another view
