Re: Where to get a new solenoid for my A 12 car
[Re: BADBEE]
#91895
07/21/08 02:33 PM
07/21/08 02:33 PM
Posts: 21,485 It's a dry heat
gtx6970
It's a dry heat
Does anyone remake these units, like this,
Nope, not good ones anyways
[Re: gtx6970]
#91896
07/21/08 03:14 PM
07/21/08 03:14 PM
Posts: 21,535 N.E. OHIO, USA
A12
N.E. OHIO, USA
I don't even think the one in photo above is correct for a '69 A12, the lead connector should be on the windshield side (rear) of the solenoid? IIRC.
[Re: Kidsixpack]
#91898
07/21/08 04:25 PM
07/21/08 04:25 PM
Posts: 610 new york
badsixpack
new york
steve, i don't think he is anymore. there is one on ebay now,just like the one in the pic,but as stated the wire connects in the wrong place. i think fredricks chrysler sells them on ebay for about 150 bucks.you might be able to cut a notch in the correct place on the housing,and just spin the guts around so the wire connects in the right place.
[Re: badsixpack]
#91899
07/21/08 07:42 PM
07/21/08 07:42 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Thats an easy fix as long as you're careful taking it apart.If you break the wire it a little harder.
[Re: BADBEE]
#91903
07/22/08 08:28 PM
07/22/08 08:28 PM
A12
N.E. OHIO, USA
My bad, I am actually needing it for my 70 6 pack Challenger and thought they would be the same as my A12 car. So no one makes them??
The '70 solenoid carb contact "pad" is round not hex as on the A12........
Re: Where to get a new solenoid for my 6 pack car
[Re: bremotorsports]
#91906
07/22/08 09:47 PM
07/22/08 09:47 PM
You need a hex-head (as pictured) solenoid stamped DR 1114420 for the A12.
GOOD LUCK!
Because you are going to need it to obtain a real one!
Bill Rolik
Really!
[Re: BADBEE]
#91910
07/23/08 05:29 PM
07/23/08 05:29 PM
BradH
So no one makes new ones????
Nobody makes CORRECT new ones. There are new replacements floating around that aren't accurate as far as the DR# stamping, etc.
[Re: BradH]
#91911
07/23/08 05:43 PM
07/23/08 05:43 PM
Posts: 3,624 Ozark Mo.
BADBEE
Ozark Mo.
[Re: BradH]
#91912
07/23/08 05:48 PM
07/23/08 05:48 PM
gtx6970
It's a dry heat
Not to mention they don't seem to work very well either.
