Where to get a new solenoid for my 6 pack car #91894
07/21/08 09:37 AM
07/21/08 09:37 AM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
Does anyone remake these units, like this,
Re: Where to get a new solenoid for my A 12 car [Re: BADBEE] #91895
07/21/08 02:33 PM
07/21/08 02:33 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Nope, not good ones anyways
Re: Where to get a new solenoid for my A 12 car [Re: gtx6970] #91896
07/21/08 03:14 PM
07/21/08 03:14 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I don't even think the one in photo above is correct for a '69 A12, the lead connector should be on the windshield side (rear) of the solenoid? IIRC.
Re: Where to get a new solenoid for my A 12 car [Re: A12] #91897
07/21/08 03:30 PM
07/21/08 03:30 PM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
I thought that Troy was making them correct?
KID
Re: Where to get a new solenoid for my A 12 car [Re: Kidsixpack] #91898
07/21/08 04:25 PM
07/21/08 04:25 PM
new york
badsixpack Offline
badsixpack  Offline
new york
steve, i don't think he is anymore. there is one on ebay now,just like the one in the pic,but as stated the wire connects in the wrong place. i think fredricks chrysler sells them on ebay for about 150 bucks.you might be able to cut a notch in the correct place on the housing,and just spin the guts around so the wire connects in the right place.
Re: Where to get a new solenoid for my A 12 car [Re: badsixpack] #91899
07/21/08 07:42 PM
07/21/08 07:42 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Thats an easy fix as long as you're careful taking it apart.If you break the wire it a little harder.
Re: Where to get a new solenoid for my A 12 car [Re: 62maxwgn] #91900
07/22/08 09:49 AM
07/22/08 09:49 AM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
My bad, I am actually needing it for my 70 6 pack Challenger and thought they would be the same as my A12 car. So no one makes them??
Re: Where to get a new solenoid for my A 12 car [Re: BADBEE] #91901
07/22/08 01:21 PM
07/22/08 01:21 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
If you have one in need of restoration, Jules (dawiperman) is the guy to go to.
His crafstmanship is second to none and he may be able to change the 'clocking' of the wiring lug for you.
Re: Where to get a new solenoid for my 6 pack car [Re: BADBEE] #91902
07/22/08 08:12 PM
07/22/08 08:12 PM
U.S.A.
Captain Flapjack Offline
U.S.A.
i think i saw in an ad from chet ?? something in new england that he has one,
in an recent mcg ad
Re: Where to get a new solenoid for my A 12 car [Re: BADBEE] #91903
07/22/08 08:28 PM
07/22/08 08:28 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
The '70 solenoid carb contact "pad" is round not hex as on the A12........
Re: Where to get a new solenoid for my A 12 car [Re: A12] #91904
07/22/08 08:42 PM
07/22/08 08:42 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
two examples of correct "looking" idle solenoids for '70/'71 on left round pad and '69 on right with the hex shaped pad......
Re: Where to get a new solenoid for my 6 pack car [Re: BADBEE] #91905
07/22/08 09:19 PM
07/22/08 09:19 PM
New Jersey Bada Bing
bremotorsports Offline
You need a hex-head (as pictured) solenoid stamped DR 1114420 for the A12.
GOOD LUCK!
Because you are going to need it to obtain a real one!
Bill Rolik
Re: Where to get a new solenoid for my 6 pack car [Re: bremotorsports] #91906
07/22/08 09:47 PM
07/22/08 09:47 PM
GOOD LUCK!
Bill Rolik
Really!
Re: Where to get a new solenoid for my 6 pack car #91907
07/22/08 09:54 PM
07/22/08 09:54 PM
That is a DR 1114429 (correct for 1970 440+6/70-71 Hemi and 71 340), that somehow was assembled with a hex head plunger. Normally the 429 has the round head plunger. Highly unusual! The 1114420 (hex-head) is for 69, and the 1114443 (hex-head with cap) is correct for 440+6 in 71.
BR
Re: Where to get a new solenoid for my 6 pack car [Re: BADBEE] #91908
07/22/08 10:45 PM
07/22/08 10:45 PM
Soldotna,Alaska
RT_6_PakShaker Offline
super street
super street
Soldotna,Alaska
Badbee The solenoid in your 1st post is probabaly a 1997405 which is a 69 Pontiac RAM AIR 400 solenoid.
Re: Where to get a new solenoid for my 6 pack car [Re: RT_6_PakShaker] #91909
07/23/08 05:16 PM
07/23/08 05:16 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
So no one makes new ones????
Re: Where to get a new solenoid for my 6 pack car [Re: BADBEE] #91910
07/23/08 05:29 PM
07/23/08 05:29 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Nobody makes CORRECT new ones. There are new replacements floating around that aren't accurate as far as the DR# stamping, etc.
Re: Where to get a new solenoid for my 6 pack car [Re: BradH] #91911
07/23/08 05:43 PM
07/23/08 05:43 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
Any contact info ???
Re: Where to get a new solenoid for my 6 pack car [Re: BradH] #91912
07/23/08 05:48 PM
07/23/08 05:48 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Not to mention they don't seem to work very well either.
Re: Where to get a new solenoid for my 6 pack car [Re: gtx6970] #91913
07/23/08 07:08 PM
07/23/08 07:08 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
I used to do then but I ran out of parts to build them...
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
