Page 1 of 3 1 2 3
5.2 EFI swap into E body suggestions? #918135
01/31/11 05:27 PM
01/31/11 05:27 PM
Canada
demon Offline OP
demon  Offline OP
Canada
I think I will be swapping a 92 5.2 Magnum into my Challenger.
I have a few questions that maybe somebody here might throw their two cents in.
First off I have 2 choices.
1. a 92 Ram 150 2WD running donor and
2. a 92 Dakota 2WD running donor
both complete trucks. My plan is to swap almost everything over.
First off, what is the best way to deal with the fuel pump?
The Challenger tank is pretty deep.
The Ram uses the 518 trans which a bit bulky but will fit. Will I need to cut/ relieve the floor or trans x member?
The Dakota uses the smaller 500 trans which ought to fit easier.
Are there trans mounts available for these O/D swaps?
Has anyone used a Ram or Dakota steering column in an E body?
Any other stuff I might look at?
I build mopars everyday so this isn't new to me, just looking for some input. Thanks!
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918136
01/31/11 05:56 PM
01/31/11 05:56 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I don't think you'll need the trans of steering column. The engine should drop right in. Then it's all about getting the harness cut in. Are you going to keep the beer keg intake or go w/ a M1?
Coming soon!!!!
Re: 5.2 EFI swap into E body suggestions? [Re: Mr.Yuck] #918137
01/31/11 06:37 PM
01/31/11 06:37 PM
Canada
demon Offline OP
demon  Offline OP
Canada
I plan on using everything I can. The entire harness, guages, etc.
That way there is NO wiring mods to make it run.
The Dakota even uses a cable speedo so that's a plus.
Actually the Dakotas had a factory tach optional too.
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918138
01/31/11 07:17 PM
01/31/11 07:17 PM
Andrewh Offline
Andrewh  Offline
Well, I didn't keep the original electonics. Wedgeman might help with some specifics there.
but I did drop a 5.9 into my b-body.
http://www.dodgecoronet.com/forum/showth...&highlight=
some of that may or may not help you.
won't say you will have less issues, just different.
you need the 360 LA pan and LA gasket for it.
I would recommend you find the van power steering unit/bracket to tuck it back in a little. will require a different belt.
I got the shumaker mounts, but you could use spacers instead.
There were a couple of people that cut the pump out of the truck and had it welded into the car tank as I recall. Allows for a returnless pump system. I didn't want to go that route.
Wedgeman managed to just wire up power to it and left it an independent harness for the computer and I believe used his own gauges.
I have no idea how you are going to cram truck gagues into an ebody. but more power to you.
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918139
01/31/11 07:20 PM
01/31/11 07:20 PM
GA
roadrunninMark Offline
GA
Demon, can you please put up pics when you do this swap? That would be excellent. How much smaller is the 500 vs 518? Also what are the power limits between the 2?
Mark
Re: 5.2 EFI swap into E body suggestions? [Re: Andrewh] #918140
01/31/11 07:30 PM
01/31/11 07:30 PM
Canada
demon Offline OP
demon  Offline OP
Canada
As for the guages, that's pretty easy. The Dakota guages are in a nice compact little rectangle unit that fits in almost any application. My buddy is doing a Dakota frame swap on a 49 ford and we have done lots of research fitting already.Dakotas are the ultimate donor
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918141
01/31/11 07:45 PM
01/31/11 07:45 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
We did an easier swap, 96 Dakota to 84 Ramcharger. The 84 318 mounts fit the Magnum block just fine. I did have to make a new trans crossmember for the 518, but that was easy. We swapped the entire 96 wiring harness and only made up what we needed for the wipers, steering column, and AC/heater. We used a cluster from a 92 Ram (electronic analog speedometer) because it fit the 84 dash.
The fuel tank is another issue. Both the Ramcharger and Dakota had plastic tanks. I believe the ultimate solution would have been a van fuel tank (mid-90s), but we couldn't find one that hadn't been punctured by the wrecking yard. We wound up using some sealant and some screws/plates to attach the Dakota pump flange to the Ramcharger tank.
Re: 5.2 EFI swap into E body suggestions? [Re: roadrunninMark] #918142
01/31/11 10:45 PM
01/31/11 10:45 PM
Canada
demon Offline OP
demon  Offline OP
Canada
Mark
I will post pics but it might be a few months.
I'm hoping to have a lot of it sorted out and engineered soon. Plan is to make it super simple so anyone can do it. Using donor vehicle parts wherever possible.
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918143
01/31/11 11:59 PM
01/31/11 11:59 PM
IN
ahy Offline
ahy  Offline
IN
For the fuel pump, a frame rail mounted high pressure pump will work with regulator in the engine compartment. Use a 3/8" pick up minimum. Aeromotive, Holley and others have pumps with the right capacity. Stay away from the super high capacity pumps like the A1000 as they are too much for the stock pickup. With a stock pickup, you should keep the tank at least 1/4 full.
There was a long post on fuel tanks for EFI last fall. If you search for it you'll find lots of other options for in tank and sumps.
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918144
02/01/11 01:35 AM
02/01/11 01:35 AM
Northwest
Four40mopar Offline
Four40mopar  Offline
Northwest
If you use the smallest avalible fuel tank from a 92-96 4 cyl Dakota it is like a fuel cell you can put in the trunk. That way you can adapt the factory fuel pump, you will have to make the lines from scratch. You can also make the fuel filler tube work with some mods. Don't forget to pull the intake manifold and replace the belly pan gasket on the bottom. Get the updated gasket from the dealer, if you don't they are known to suck/burn oil.
Re: 5.2 EFI swap into E body suggestions? [Re: Four40mopar] #918145
02/01/11 02:06 AM
02/01/11 02:06 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
You may not have to make lines from scratch to use the Dakota pump. We couldn't use the Dakota lines due to the location of the tank, but we grabbed the lines from a short wheelbase van and the fit was perfect in our Ramcharger, which I believe, has a similar wheelbase to an E-body.
Re: 5.2 EFI swap into E body suggestions? [Re: Jim_Lusk] #918146
02/01/11 02:48 AM
02/01/11 02:48 AM
Canada
demon Offline OP
demon  Offline OP
Canada
Great tips so far! Thanks everyone!
I have the Dakota guage cluster in front of me right now and it will be easy to adapt. The E body dash is wide open with the stock guages out. Tons of room to fit and all nice flat straight angles to make my faceplate simple. Won't look like stock guages but will function 100% and have all the Dakota features intact. Tomorrow I'll compare steering columns. I have them both out. Looks like a simple changeover too.
I'd say the E body/Dakota morph will be quite slick. The rear diff is actually pretty close too so I may stick it in as well so I have the antilock rear brakes too.
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918147
02/01/11 02:51 AM
02/01/11 02:51 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The Dakota we parted had a 3.55 geared 8-1/4, but it didn't have a sure grip and I let it go with the trailer that I made out of the bed as I didn't have anything else. SO, check those gears.
Re: 5.2 EFI swap into E body suggestions? [Re: Jim_Lusk] #918148
02/01/11 02:53 AM
02/01/11 02:53 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Oh, and here is the trailer that I made. I couldn't find a buyer for the bed, so........I also got $400 for it.
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918149
02/01/11 10:38 AM
02/01/11 10:38 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yes I have a 95 Sport Dak w/ a 5.2. Seems like a lot of work that might not be needed. I'm guessing you'd swap the wheel out? The column is awfully fat. Not sure you could get it in the e-body w/ some cutting.
Re: 5.2 EFI swap into E body suggestions? [Re: Mr.Yuck] #918150
02/02/11 07:57 AM
02/02/11 07:57 AM
Finland
mafo Offline
mafo  Offline
Finland
I m working on a similar swap here, 318/a500 in a 55 coronet but my motor is out of a 94 grand cherokee and trans is from a van I believe.
anyhow, about power steering pumps, jeep has a different bracket that
places the pump very close to the waterpump, maybe something to look into
another thing about jeeps, you can t use jeep exhaust manifolds with "normal" starter position, I guess GC has the starter on the other side?
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: 5.2 EFI swap into E body suggestions? [Re: Mr.Yuck] #918151
02/03/11 06:13 PM
02/03/11 06:13 PM
Canada
demon Offline OP
demon  Offline OP
Canada
so today I placed the E body column and the Dakota column side by side and did some measuring. They are identical tube diameter. Overall tube length very close. Shaft is different but easily modified by combining the two or using an intermediate shaft like a 72-93 Dodge 4x4. The upper column and plastic covers etc all work fine. I test fit it into the dash too and only minor trimming to the Dakota plastic covers needed. This will be no problem putting the Dakota column in. Only thing I didn't do yet was pull the Dakota steering wheel off to see If the splines will accept the E body soup can.
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918152
02/03/11 06:24 PM
02/03/11 06:24 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what did you do about the big plastic boxey mass that houses the key, hazards, wiper and turn signal switches???
Re: 5.2 EFI swap into E body suggestions? [Re: Mr.Yuck] #918153
02/03/11 08:29 PM
02/03/11 08:29 PM
Canada
demon Offline OP
demon  Offline OP
Canada
that plastic boxy unit fits just fine. Doesn't look stock for an E body, but does blend in reasonably well. Hoping the E body can and wheel fit right on
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918154
02/04/11 12:26 AM
02/04/11 12:26 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Why not a FAST EZ efi?
Re: 5.2 EFI swap into E body suggestions? [Re: Dragula] #918155
02/04/11 12:35 AM
02/04/11 12:35 AM
Canada
demon Offline OP
demon  Offline OP
Canada
I can buy a running Dakota for $500-$1500 and get every piece I need. All mopar and cheap
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918156
02/04/11 07:15 PM
02/04/11 07:15 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
As for the differences between the 500/518 case sizes, they're negligible. The overdrive section measures the same, and from that point forward you're talking the difference between a 904 and a 727. Both transmissions will require cutting the transmission cross member and welding a piece of fitted flat stock in its place. Make your decision based on the condition of the two, and intended use. Size matters not (obligatory Star Wars quote).
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918157
02/04/11 11:01 PM
02/04/11 11:01 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
I am beginning the same type of swap on a 68 fury 4door (why?) although I am not using the whole harness. I am going to splice the original harness with the underhood one from the Dakota. I have a friend with some experience in this, but he says there are only 5 or so wires to splice on OBD1. As for fuel system, I have a '71 tank in the car already so it has some vapor return ports. The LS1 corvettes use a fuel filter with a built in regulator, it has in, out and return, so I plan on using an inline pump. I was able to score a deal on a 95 dak with a 5.2 but a blown trans, but my car has a good 727 so I am going to use it for now. Sorry for the long post, but I thought I was the last one trying to do a EFI magnum swap!
Re: 5.2 EFI swap into E body suggestions? [Re: MarkZ] #918158
02/04/11 11:19 PM
02/04/11 11:19 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
actually, there was a post here years ago for E and '71 up B's that put a 518 in them WITHOUT cutting the t-bar xmember, but by trimming some of the ribs on the OD case....dunno if anyone has the pics saved anymore...
2017 Grand Cherokee Overland
Re: 5.2 EFI swap into E body suggestions? [Re: patrick] #918159
02/05/11 02:57 AM
02/05/11 02:57 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
A few of items to note:
1)The 92 5.2L was a return fuel system 40 psi with pump in the tank and a regulator on the fuel rail.93 up uses the returnless system with a bypass and pump in the tank.40 psi until 96.Switch the fuel rail to 93-95 type.
2)There is a very shallow Jeep tank that might bolt in.It has the pump and bypass in the tank.It will need to be modified slightly to fill it of course.
3)You can patch in the Magnum harness to the vehicle harness-8 wires
Leave the gun.......take the Cannoli's....Mike
Re: 5.2 EFI swap into E body suggestions? [Re: mike s] #918160
02/05/11 04:58 PM
02/05/11 04:58 PM
Canada
demon Offline OP
demon  Offline OP
Canada
right on! Thanks. That's some good info
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918161
02/05/11 07:44 PM
02/05/11 07:44 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Nothing to add, just watching this post too as I want to do something similar with my 4dr Satellite. I don't need a drag-strip terror, just want a reliable driver.
John
Re: 5.2 EFI swap into E body suggestions? [Re: SattyNoCar] #918162
02/05/11 08:39 PM
02/05/11 08:39 PM
GA
GA
Mark and Pat, thanks for the info on the trans differences and such. If anyone can find those older pic for shaving down the casing to make it fit, that would be excellent.
Also, is the gearing different between the two?
Re: 5.2 EFI swap into E body suggestions? [Re: roadrunninMark] #918163
02/07/11 12:05 PM
02/07/11 12:05 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
A500/42RH uses the low gear 904 setup: 2.74/1.54/1/.69 OD
A518/46RH uses the standard 727 setup, 2.45/1.45/1/.69 OD
I'm running a 42RH in my 5th ave. mark is switching from a 42RH to a 46RH.
Re: 5.2 EFI swap into E body suggestions? [Re: patrick] #918164
02/07/11 12:45 PM
02/07/11 12:45 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Re: 5.2 EFI swap into E body suggestions? [Re: ralphie361] #918165
02/11/11 02:01 AM
02/11/11 02:01 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Update on this car. Here is some progress pics of the harness. It is pretty easy to strip this harness down to what is not needed. It will use the ASD and Fuel Pump relay.
The three loops of wire are fo 12v feed, 12v run/ign feed, and 12 out to fuel pump (from relay)
Still need to finish wrapping it back up, and tie up a couple loose ends.
Justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: 5.2 EFI swap into E body suggestions? [Re: wldtm] #918166
02/11/11 02:02 AM
02/11/11 02:02 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
another...
Re: 5.2 EFI swap into E body suggestions? [Re: wldtm] #918167
02/11/11 02:03 AM
02/11/11 02:03 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
one more...
Re: 5.2 EFI swap into E body suggestions? [Re: wldtm] #918168
02/27/11 08:47 PM
02/27/11 08:47 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Update on the Fury, engine out, trans notched, but I need a different converter. The one in the car had 11inch bolt spacing and I need one with 10 inch to fit inside the magnum flex plate. Should be bolted together in the next few weeks.
Re: 5.2 EFI swap into E body suggestions? [Re: ralphie361] #918169
02/27/11 08:51 PM
02/27/11 08:51 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Here is the car its going in.
Re: 5.2 EFI swap into E body suggestions? [Re: ralphie361] #918170
03/20/11 07:19 PM
03/20/11 07:19 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Update on the Fury, engine in, no problems there. Modified the gas pedal assembly to accept the dakota throttle cable, and the exhaust will have to be fabricated, but other than that no issues. Now for wiring and fuel system.
Re: 5.2 EFI swap into E body suggestions? [Re: ralphie361] #918171
03/20/11 07:36 PM
03/20/11 07:36 PM
Canada
demon Offline OP
demon  Offline OP
Canada
Love your Fury. Great looking car!
The 5.2 looks like a natural in there.how about some details. Did you get the harness figured out?
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918172
03/20/11 09:20 PM
03/20/11 09:20 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Great info, I'll be watching this. I have a 40 Plymouth with a 92 Dakota drivetrain and harness on the back burner. Sure hope a MOD will bumpe this to the tech archive when it's done....
Re: 5.2 EFI swap into E body suggestions? [Re: RodStRace] #918173
03/20/11 09:46 PM
03/20/11 09:46 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
The harness should be installed by the end of this week (time allowing). Hopefully some pics will be taken. If you want to build your own harness PM me if you need some help or I have another one done for this swap if you want to purchase one. It will be nice to see how this first one goes. This should be a very nice driver, that anyone can drive and start without setting the choke. Looks good Ralph!
Re: 5.2 EFI swap into E body suggestions? [Re: wldtm] #918174
03/20/11 11:11 PM
03/20/11 11:11 PM
Andrewh Offline
Andrewh  Offline
did you swap out the column yet? or did you give up on that?
Re: 5.2 EFI swap into E body suggestions? [Re: Andrewh] #918175
03/20/11 11:40 PM
03/20/11 11:40 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
the gentlemen with the fury in the pic wasnt going to do that. we made our own harness. we just posted pics to this thread because he was doing something similar to the 5.2 in the E body. this car (gold fury) used factory dakota wiring harness modified and the 5.2. he is trying to do this as simple as possible.
justin
Re: 5.2 EFI swap into E body suggestions? [Re: wldtm] #918176
03/22/11 10:09 PM
03/22/11 10:09 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Fired the car up for the first time tonight! Plugged in most of the harness, and tapped 12V off of the alternator and 12v ignition on source off of the old coil wire, temporarily. If you take out the ballast resistor and jumper the terminals you get full 12V on start and run position in the ignition switch. Still did not plumb a fuel system, just running it off of a pressurized tank for the moment. Now for permanent wiring since I know it works. Thanks to Justin (wldtm) for all of his help on this car
Re: 5.2 EFI swap into E body suggestions? [Re: ralphie361] #918177
03/23/11 01:21 AM
03/23/11 01:21 AM
Canada
demon Offline OP
demon  Offline OP
Canada
excellent!
I'd sure like to know what wires are necessary for making the engine and computer function so I can retain my stock dash etc if I go that way. Nice job!
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918178
03/23/11 08:13 AM
03/23/11 08:13 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Keep these PINs per a 94 dakota service manual
PINS
1 map sensor
2 ECT sensor
3 Battery feed
4 sensor return
6 5v supply
7 8v supply
9 Ignition feed
10 not needed with 727
11 Ground
12 Ground
13 Inj Driver4
14 Inj Driver3
15 Inj Driver2
16 Inj Driver1
17 Inj Driver7
18 Inj Driver8
19 Ign Coil Driver
20 Gen Feild Driver
21 Air Temp Sensor
22 TP Sensor
24 Reference Pickup
25 Data link
27 AC compressor (if keeping AC)
29 Brake sense (if keeping cruise)
30 P/N switch
32 MIL
33 VSS (if keeping dakota cruise) we got rid of)
34 AC WOT relay (if keeping ac- we got rid of)
35 EGR Solenoid (we deleted EGR)
37 Trans OD light (we got rid of)
38 Inj Driver5
39 IAC
40 IAC
41 Heated O2 Sensor
43 Tach (we kept)
44 CMP sensor
45 Data llink
47 VSS pick up (we kept for now) KEEP 47-50, 53 keep if using dakota cruise
48 VSS set/coast (we got rid of)
49 VSS on/off (we got rid of)
50 VSS resume/accel
51 ASD relay and fuel pump relay driver
52 Evap purge (we got rid of)
53 VSS vent (we got rid of)
54 EMCC solenoid (we got rid of)
55 Trans OD solenoid (we got rid of) (keep if using 42rh or 46rh)
57 ASD bat supply
58 Inj Driver6
59 IAC
60 IAC
The best thing to do is build a wiring harness using a 94-95 dakota schematic. You will need an ASD and fuel pump relay socket. This is the part where you will need to do a little modifying.
It depends on how much stuff you want to keep. You could keep AC, overdrive trans, and cruise if you wanted to...
Use the vehicles stock sending unit to run gauges ex) temp, oil psi, volts
I can make this harness for interested parties
Re: 5.2 EFI swap into E body suggestions? [Re: ralphie361] #918179
03/26/11 10:19 PM
03/26/11 10:19 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Found an oversight in my parts selection this afternoon. 5.2 and 5.9 magnums use the same oil pan, not like 318 vs 360 LA. When I first filled it with oil I had a leak and chalked it up to me screwing up the gasket install. After the second one this afternoon leaked I looked it up online and got conflicting stories. MP tech line confirmed that I need a 360 car pan instead of the 318 pan for the 5.2 or 5.9, and they said the one piece rubber gasket should work. Minor issue, but annoying!
Re: 5.2 EFI swap into E body suggestions? [Re: ralphie361] #918180
03/26/11 10:57 PM
03/26/11 10:57 PM
Andrewh Offline
Andrewh  Offline
the one piece does not work. I know. unless you adjust the pan, it will leave a gap at the front and back of the motor. you need to use the LA gasket set.
Re: 5.2 EFI swap into E body suggestions? [Re: Andrewh] #918181
03/26/11 11:17 PM
03/26/11 11:17 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Thanks for the heads up, I ordered the one piece and the old style gasket when I ordered the pan, just in case!
Re: 5.2 EFI swap into E body suggestions? [Re: ralphie361] #918182
04/02/11 07:50 PM
04/02/11 07:50 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Plumbed the fuel lines on the Fury today and ran power to the pump and the fuel system is working. Used a mopar pump from the magnum mpi conversion kit, and an ls1 corvette filter with regulator. Without spending the big bucks on a sumped tank with internal pump, the fuel system isnt as clean as I had hoped, but it works. I drove the car around the block this afternoon, pretty pumped! Now to tidy up the wiring and hang an exhaust on it.
Re: 5.2 EFI swap into E body suggestions? [Re: ralphie361] #918183
04/02/11 09:05 PM
04/02/11 09:05 PM
Andrewh Offline
Andrewh  Offline
if you ever plan on putting in dual exhause you might want to re think that mount.
I put mine in without exhause and found that long idle times, like stop and go traffic will kill the pump. when it is that close.
Re: 5.2 EFI swap into E body suggestions? [Re: Andrewh] #918184
04/02/11 10:47 PM
04/02/11 10:47 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Yeah, I actually took off one of the tailpipes from the duals that were on there to mount it there. To get the pump low enough, but still close to the tank that is one of the compromises I made. I figure if I upgrade the engine, I'll probably upgrade the fuel system to match with an in tank setup.
Page 1 of 3 1 2 3
