Re: Another question about compression, '68 340 j heads cut
[Re: MonGoo$e]
#917490
01/30/11 11:49 PM
01/30/11 11:49 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
'68, '69 (& maybe '70-71) 340's were factory rated at 10.5:1 compression. They were the only factory SB with pistons ABOVE deck (not sure about HP 273's). The factory listed compression ratio may have been a little bit high, but with shaved heads on an early 340, you will still be in the 10.5- 11:1 compression range. You can install thick head gaskets (commetic?) to help lower the compression ratio.
'72-'73 340's used a lower compression piston with 4 eyebrows cut in them instead of the earlier 2.
FWIW, my 10.5:1 '69 340 runs just fine on 93 octane pump gas... and as I said, the factory compression ratings may have been a touch on the high side.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
