Larin engine test stand ? #917346
01/30/11 05:07 PM
01/30/11 05:07 PM
templeton,ma
coro500net Offline OP
templeton,ma
Has anybody used this test stand for a big block mopar? The stands motor mount supports do not fit a mopar (im sure they fit chevy)just wondering if anybody else has the same problem.It does not fit the block bosses or with the motor mount brackets installed.
Re: Larin engine test stand ? [Re: coro500net] #917347
01/30/11 05:56 PM
01/30/11 05:56 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Most engine test stand mounts fit a chevy.You will have to fab your own mounts for any thing else.
Re: Larin engine test stand ? [Re: gtx69] #917348
01/30/11 09:31 PM
01/30/11 09:31 PM
templeton,ma
templeton,ma
Thats a real shocker
They say it fits most engines,why dont they say fits chevy and thats it?I can modify it without much trouble,but what is the best way to attach the engine to the stand?should I mount it to the block bosses or do i use the motor mounts?
Re: Larin engine test stand ? [Re: coro500net] #917349
01/30/11 09:51 PM
01/30/11 09:51 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Block bosses that you use for the motor mounts.
Re: Larin engine test stand ? [Re: gtx69] #917350
01/31/11 09:04 PM
01/31/11 09:04 PM
templeton,ma
templeton,ma
Thanks for the info
Re: Larin engine test stand ? [Re: coro500net] #917351
01/31/11 09:55 PM
01/31/11 09:55 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
You're welcome
