ok so say one gets a low band apply RMVB w/o trans break. how should they burn out? still 2 to 3? couldnt you then go from 1st? i want a mvb for my street (AH! the S word! not in the race forum!) car, and i want all the benifits of street car: downshifting, burn outs. with out all that pesky transmission explosion.
When racing, burnouts should start off in 2nd then shift to 3rd.On a steet car , well, we all do burn outs starting off in 1st gear,So I would have to say , shift into 2nd gear as quick as you can. Maybe Jim727 can chime in on this one.
I've got a Cheetah reverse Manual VB in the car and bolt-in sprag lying on the shelf, waiting installation.
So, in a transmission with a rev.manual-valvebody without lowband apply, how much of a protection against tranny blow-up is a bolt-in sprag?
A bolt in sprage keeps the outer sprage race from spinning in the case, It does not protect the springs and rollers.Low band apply VBs do help protect the springs and rollers , as the low band is ON when in first gear,
