Pushbutton T-Flite Question #916104
01/28/11 10:15 PM
01/28/11 10:15 PM
Greer, SC
TooMany62s Offline OP
Greer, SC
As far as I can tell my '62 convert has a leak where the park cable goes into the housing at the rear of the trans. I'm pretty sure there's an O-ring around that cable end. What's involved in changing that o-ring? Do I need to drain the trans before I remove the park housing?
Re: Pushbutton T-Flite Question [Re: TooMany62s] #916105
01/28/11 10:22 PM
01/28/11 10:22 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Nope .. just open that allen plug and let it drain a bit from there. And rust and or corrosion is what probably hurt that o-ring.
Re: Pushbutton T-Flite Question [Re: TooMany62s] #916106
01/28/11 10:30 PM
01/28/11 10:30 PM
Casco, MI
Savoy1964 Online content
Savoy1964  Online Content
Casco, MI
There is a o-ring you will have some fluid come out that has accumulated in the tail shaft area. removing the allen headed plug then loosening the locking nut on the side tap in the nut to loosen the locking system, then using a screwdriver you need to push up on locking spring and pull on cable to remove. Install you use screwdriver to hold back on the washer to insert the cable end and have it lock. Last time I had to remove the cable I had to unbolt the entire housing with the 5 attaching bolts.
(As far as I know you cant get the gasket that seals that housing most likely you'll have to RTV it.)
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Pushbutton T-Flite Question [Re: TooMany62s] #916107
01/29/11 12:57 AM
01/29/11 12:57 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Rick,I have about a dozen gasket's and the correct O ring,let me know what you need.
Re: Pushbutton T-Flite Question [Re: 62maxwgn] #916108
01/29/11 01:55 AM
01/29/11 01:55 AM
Greer, SC
Greer, SC
Bill, I'm pretty sure I have a gasket. Is the O-ring anything special or is it a hardware store item?
Re: Pushbutton T-Flite Question [Re: TooMany62s] #916109
01/29/11 11:18 AM
01/29/11 11:18 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Rick,the outside diameter is .420,I have an O-ring kit with over a hundered O-rings,has about a dozen this size so I would suppose it's a standard item.
Re: Pushbutton T-Flite Question [Re: 62maxwgn] #916110
01/29/11 03:35 PM
01/29/11 03:35 PM
Central New York
bfury Offline
bfury  Offline
Central New York
My '63 has the same kind of problem, does the shift cable also use a gasket or o ring to keep it from leaking? Also I put in a deep Mopar pan and ever since it will not come out of 1 st gear and sounds like it is slipping. Any ideas?
No Stock
Re: Pushbutton T-Flite Question [Re: TooMany62s] #916111
01/29/11 06:59 PM
01/29/11 06:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you're just going to replace the O ring there's no need to pull the housing, just remove the cable.
Re: Pushbutton T-Flite Question [Re: bfury] #916112
01/29/11 07:55 PM
01/29/11 07:55 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
There is an o ring on the shift cable. When you put on the deep pan, I assume that you also installed a pickup extension. You must have the early extension and early filter (with two holes) to feed the rear pump.
