Not sure about the B&M prostick.
But I just installed a Hurst Pro-Matic2 in my Dart. Its the same shifter for Ford,GM,Chrysler. The shifter comes with different mounting brackets for the transmission end of the cable, and with transmission shift levers for ford,gm,chrysler. you just look at the instructions and figure out which one you need.
If your buying one at a swap meet, you could probably get the correct cable mount and trans lever from B&M.
I've only driven my Dart a couple times since installing the new shifter, but I love it so far.
