440 stealth heads and roller cam
#913809
01/25/11 05:13 PM
01/25/11 05:13 PM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
anyone use the stock china valves in stealth heads with roller cam,should i get ferrea 6000 series valves(done that in all my steel heads)?will be using 1.5 harland sharp roller rockers also.
MOPAR OR NO CAR
Re: 440 stealth heads and roller cam
[Re: hemigod426]
#913810
01/25/11 06:13 PM
01/25/11 06:13 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I think you already know the answer..China and 500 plus lbs of spring pressure...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
