MC Bore Size: 1 1/8 vs. 1 1/32
#913750
01/25/11 04:34 PM
01/25/11 04:34 PM
Posts: 284 Louisiana
kzinge1
Louisiana
I have the SSBC disc brake conversion on the front of my 69 RR and 10.5" drums in the rear. I am not using the booster that came with the kit. I am running the Strange 1 1/8" bore master cylinder right now and the brake pedal is too hard and the car doesn't stop well enough. Will the Strange 1 1/32" bore master cylinder be right for this combo or do I need to go even smaller than that?
Re: MC Bore Size: 1 1/8 vs. 1 1/32
[Re: Stanton]
#913755
01/25/11 08:56 PM
01/25/11 08:56 PM
kzinge1
Louisiana
Keep in mind that less effort means more travel ... you still have to move the same amount of fluid !!! That said, the most common m/c for a brake conversion seems to be the 1-1/32".
A lot depends on caliper piston size as well. The least pedal effort will be achieved with a small m/c bore and a large caliper piston. Determine the size of your pistons versus the mid-70's Mopar calipers. If yours are the same or larger then the 1-1/32" m/c should be fine but if yours are smaller then you'll want to go smaller on the m/c as well.
I believe I have 4 piston calipers, if I remember correct. Should be bigger than factory. Do you know what the bore size was of the mid-70s Mopar MC's?
[Re: kzinge1]
#913756
01/25/11 09:00 PM
01/25/11 09:00 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If "the pedal is too hard and the car doesn't stop well enough" I'd say the problem isn't the MC size. With a booster it should stop well if the parts are properly installed.
Have you checked to see that the rear piston in the MC is fully returning?
[Re: kzinge1]
#913759
01/25/11 09:40 PM
01/25/11 09:40 PM
Challenger 1
Cincinnati, Ohio
Yep, no booster.
Maybe that's why... I think you would need different petal linkage/ratio and MC bore size with manual verse power brakes.
It's best to call the guys you bought the brake kit from.
[Re: kzinge1]
#913760
01/25/11 09:57 PM
01/25/11 09:57 PM
RapidRobert
As said I'd call/email them & see if the pedal ratio and or the bore size is OK w you not using the booster
[Re: kzinge1]
#913763
01/25/11 10:39 PM
01/25/11 10:39 PM
Posts: 7,664 IN
ahy
IN
Was your car originally manual or PB? Reason I ask is the PB pedal linkage setup gives less leverage. If you are running the PB pedal linkage without booster that's your first and biggest problem. The MC size would be secondary.
[Re: kzinge1]
#913766
01/26/11 12:27 AM
01/26/11 12:27 AM
Posts: 8,867 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
This is incorrect. The actual pedal and linkage is the same for both power and manual brakes. The leverage change is accomplished with a mechanism that is actually part of the booster assembly (if you notice, the booster rod is actually higher up on the firewall than the manual rod - as a result of this mechanism). If you were to try to use that mechanism with a manual m/c it wouldn't mount properly and I doubt you'd find a pushrod to fit.
[Re: kzinge1]
#913772
01/26/11 12:04 PM
01/26/11 12:04 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
Thanks alot guys! Lots of knowledgeable people in this thread, I think you guys have me on the right track. I do have the adjustable prop. valve that came with the kit but I didn't install it. I guess that would solve the rear bias issue with the new MC. Or would I still need the 7/8 bore wheel cylinder?
Dr. Diff, I'll be sending an e-mail shortly.
I would just change out to the 7/8 bore rear wheel cylinders and then you shouldn't need the adjustable valve in the rear line .
[Re: JohnRR]
#913773
01/26/11 03:40 PM
01/26/11 03:40 PM
kzinge1
Louisiana
Seems like you could use one or the other. I don't know, I'll go with whatever Dr. Diff recommends. I do already have the adj. valve though, just haven't installed it.
