Re: MC Bore Size: 1 1/8 vs. 1 1/32 [Re: kzinge1] #913770
01/26/11 02:15 AM
01/26/11 02:15 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You have a common problem associated with the SSBC brake kit.
You need a 15/16" bore master cylinder and 7/8" bore rear wheel cylinders.
I stock the parts you need. E-mail me if you are interested.
Re: MC Bore Size: 1 1/8 vs. 1 1/32 [Re: DoctorDiff] #913771
01/26/11 02:57 AM
01/26/11 02:57 AM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
Thanks alot guys! Lots of knowledgeable people in this thread, I think you guys have me on the right track. I do have the adjustable prop. valve that came with the kit but I didn't install it. I guess that would solve the rear bias issue with the new MC. Or would I still need the 7/8 bore wheel cylinder?
Dr. Diff, I'll be sending an e-mail shortly.
Re: MC Bore Size: 1 1/8 vs. 1 1/32 [Re: kzinge1] #913772
01/26/11 12:04 PM
01/26/11 12:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would just change out to the 7/8 bore rear wheel cylinders and then you shouldn't need the adjustable valve in the rear line .
Re: MC Bore Size: 1 1/8 vs. 1 1/32 [Re: JohnRR] #913773
01/26/11 03:40 PM
01/26/11 03:40 PM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
Seems like you could use one or the other. I don't know, I'll go with whatever Dr. Diff recommends. I do already have the adj. valve though, just haven't installed it.
