Re: Torque specs on front end rebuild
[Re: Mike H]
#913361
01/25/11 12:17 AM
01/25/11 12:17 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I just did mine this past month. I used an old Chiltons manual. But no I would not "just "get after it"". I can't get the numbers tonight but I could do so tomorrow night if you still need them.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: Mike H]
#913363
01/25/11 12:54 AM
01/25/11 12:54 AM
RapidRobert
Grease all the zerks & keep LCA tapered shaft front pivot nuts and UCA cam bolt nuts only lightly snugged then YOU set the ride height on a level surface/tires aired to your preferred psi/your weight in barbells in dr seat. Set the ride height (Tbar adj bolts) where you like the height (jounce it after each adjustment) and the look/fit of the front wheels in the wheel wells b 4 you get to the shop. Tow it in & drive it onto the rack then pull the weights back over to to the dr side & pile them up in the center of the dr seat b 4 you exit the vehicle. Give the tech a twenty to take his time & get as much positive caster as he can & to take his time & get everything near spot on EDIT Tell him not to change the ride height. When done & he tightens things have him tighten the UCA cam bolt nuts TIGHT
