Rollbar rules NHRA for 11.0's #911769
01/23/11 07:27 PM
01/23/11 07:27 PM
Ohio
Bratt Racing Offline OP
Ohio
Does anyone know what the rollbar rule is for NHRA for a 11.0 car?
Re: Rollbar rules NHRA for 11.0's [Re: Bratt Racing] #911770
01/23/11 07:38 PM
01/23/11 07:38 PM
okla.
sam64 Offline
sam64  Offline
okla.
6 point down to 9.99 if firewall is stock unmodified.
Re: Rollbar rules NHRA for 11.0's [Re: Bratt Racing] #911771
01/23/11 07:47 PM
01/23/11 07:47 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
2011 rule book - general regs.
4:10 ROLL BAR
All roll bars must be within 6 inches of the rear, or side, of the driver’s head, extend in height at least 3 inches above the driver’s
helmet with driver in normal driving position or be within 1 inch of the roof/headliner in the area above the driver's helmet, and be at least as wide as the driver's shoulders or within 1 inch of the driver's door. Roll bar must be adequately supported or crossbraced to prevent forward or lateral collapse. Rear braces must be of the same diameter and wall thickness as the roll bar and intersect with the roll bar at a point not more than 5 inches from the top of the roll bar. Crossbar and rear braces must be welded to main hoop. Sidebar must be included on driver’s side and must pass the driver at a point midway between the shoulder and elbow. Swing-out sidebar permitted. All roll bars must have in their construction a cross bar for seat bracing and as the shoulder harness attachment point; cross bar must be installed no more than 4 inches below, and not above, the driver’s shoulders or to side bar. All vehicles with OEM frame must have roll bar welded or bolted to frame; installation of frame connectors on unibody cars does not constitute a frame; therefore it is not necessary to have the roll bar attached to the frame. Unibody cars with stock floor and firewall (wheeltubs permitted) may attach roll bar with 6-inch x 6-inch x .125-inch steel plates on top and bottom of floor bolted together with at least four 3/8-inch bolts and nuts, or weld main hoop to rocker sill area with .125-inch reinforcing plates, with plates welded completely. All 4130 chromoly tube welding must be done by approved TIG heliarc process; mild steel welding must be done by approved MIG wire feed or approved TIG heliarc process. Welding must be free of slag and porosity. Any grinding of welds prohibited. Roll bar must be padded anywhere driver’s helmet may contact it while in driving position. Adequate padding must have minimum 1/4-inch compression or meet SFI Spec 45.1. Beginning June 1, 2011, all cars running 9.99 (*6.39) or quicker, SFI Spec 45.1 mandatory.
Re: Rollbar rules NHRA for 11.0's [Re: sam64] #911772
01/23/11 07:58 PM
01/23/11 07:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont have a new rule book but technically a 5 point
works... down bar has to be on the drivers side
Re: Rollbar rules NHRA for 11.0's [Re: MR_P_BODY] #911773
01/23/11 08:02 PM
01/23/11 08:02 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Rollbar rules NHRA for 11.0's [Re: bigtimeauto] #911774
01/23/11 08:13 PM
01/23/11 08:13 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
6pt w an 11.50 car,use to be 12sec until vettes ran 11's w the zo6 street car
Re: Rollbar rules NHRA for 11.0's [Re: MR_P_BODY] #911775
01/23/11 08:17 PM
01/23/11 08:17 PM
Ohio
Ohio
Thanks for the information everyone.
I'm planning on doing 5th and 6th point for some reason I thought you had to 8 or 10.
Re: Rollbar rules NHRA for 11.0's [Re: Bratt Racing] #911776
01/23/11 09:21 PM
01/23/11 09:21 PM
Locomotion Offline
Locomotion  Offline
An 8 point would be helpful in stiffening the chassis more with the extra 2 bars behind the seats running from the cross bar/main hoop junction to the frame connectors.
