STEERING COLUMN FIX #911005
01/22/11 08:43 PM
01/22/11 08:43 PM
IL . usa
cjs69mope Offline OP
IL . usa
Has anyone used red lock tight to assemble the collapsible section of the steering shaft where the plastic was from the factory? Would this be OK and hold the shaft together enough ? sorry if this is a redundant question.
1969 Dodge Charger 1969 Dodge Superbee
Re: STEERING COLUMN FIX [Re: cjs69mope] #911006
01/22/11 08:57 PM
01/22/11 08:57 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Some guys like to use superglue, some JB weld, I prefer Loctite 1 ton 5 minute epoxy
