Re: 340 crank in a 318 from factory?
[Re: babarracuda]
#910297
01/21/11 07:56 PM
01/21/11 07:56 PM
Posts: 2,177 ill
dennismopar73
ill
ive owne to date 2 68 318 with steel cranks , and bushed rods,,!! right out of fact
[Re: 68GTS383]
#910298
01/21/11 09:17 PM
01/21/11 09:17 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
318's of that era were cast crank in a Scamp. Nice find, but not stock.
[Re: Gabmando]
#910303
01/22/11 12:09 PM
01/22/11 12:09 PM
Supercuda
About to go away
About to go away
up yours
biggest difference is balance, 340 rod and piston combo is more than the 318's in weight.
[Re: ozz383]
#910305
01/22/11 01:56 PM
01/22/11 01:56 PM
Supercuda
About to go away
About to go away
up yours
Early teens had lighter rods, later on they commonized to the heavier rods. Piston wieght is different too, 318 is lighter.
As for balancer, not 100% what, if any, difference there is. I don't have a parts book handy to see if they are the same number or not.
[Re: 68GTS383]
#910307
01/22/11 03:17 PM
01/22/11 03:17 PM
Posts: 1,072 The Sunny Shuswap
dodgefarmer
The Sunny Shuswap
No one has answered my main question:Were 340 cranks the only SB cranks that were drilled?
No, 273's were drilled.
Randy
[Re: 68GTS383]
#910308
01/22/11 03:34 PM
01/22/11 03:34 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
What do you nmean by DRILLED ??? All cranks are drilled to balance them, even the lowly 318.
[Re: dennismopar73]
#910311
01/22/11 11:10 PM
01/22/11 11:10 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
both my 68s have steel cranks..
