Cheap fiberglass hoods #910229
01/21/11 02:09 PM
01/21/11 02:09 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
I found this place on ebay and thought the prices were pretty good so i figured i would post on here to see if any one could benefit. Dont kno the quality... Hope it helps someone
http://stores.ebay.com/rgclmc77
Re: Cheap fiberglass hoods [Re: Jonnyj00] #910230
01/21/11 10:55 PM
01/21/11 10:55 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I have been told that this is the fiberglass guy that used to supply the 'glass parts for MAS Products in MN that are no longer in business. They used to advertise in all the Mopar Mags, but haven't seen the ads in quite a while; his prodduct line seems the same. I'm playing with a car now that has a MAS hood that was bought in 1995 and is still holding up well. Hood opening was the size of the scoop and the owner closed it up a little to make sealing the carb easier with a smaller pan...that added some strength as well. Overall a GREAT buy (back then) at least for couple of hundred he paid for it!
