Re: sheet metal intake where to it from [Re: hemiiroc] #909037
01/21/11 12:28 AM
01/21/11 12:28 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Weinle is the best deal I've found........... http://www.weinlemotorsports.com/intakes.php
Don't make that mistake
Why is that? He quoted me $600 for a 'kit' of a low deck single carb tunnel ram, I'd have to have a buddy weld it up.
I decided not to go this route as HardcoreB has a great deal on an Indy TR but now I've decided to stick with what I have.
Re: sheet metal intake where to it from [Re: earthmover] #909038
01/21/11 02:05 AM
01/21/11 02:05 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
thanks bigdad but wow is all i can say they must work great for the price
Hogan's is one of the cheaper places to get one, but is probably the best bang for the buck. Because of the sheer volume of manifolds they do, they can price them lower. Most everyone else starts at 3k. A Wilson will cost you 6-8k. It's like anything else, you get what you pay for. LOTS more to it, than bending up some sheet aluminum and welding it together........at least there is if you want it to make power.
Monte
Re: sheet metal intake where to it from [Re: moderncylinder] #909039
01/21/11 02:08 AM
01/21/11 02:08 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
its marcella,,, marcella manifolds,, john worked for me for about 6 months about 10 years ago,,, he will get 3500 or so for one...
john beck's wont look as nice cause he has an older welder than marcella,,, he will get 2500 or less
4.5 inch runner,, 7-8 degrees total taper,, make the plenum 5 inches deep from lid
His(Marcella) stuff is a work of art....
MB
Re: sheet metal intake where to it from [Re: HPMike] #909040
01/21/11 04:06 AM
01/21/11 04:06 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
How about making billet runners ?
Lets say there could be a runner length and taper that would work good for 540-572 B1 orig. heads that at least 4 or more could use. We could then ask for a price, like a group buy.
I bet there is lots of costs to be saved in programming and fixture for milling these in a 5-axis cnc mill.
I would like to have o-rings and four allen bolts 1/4 or smaller in both ends of the runner.
If you change deck height in a future build, you could use the runners for another engine and build a new plenum.
My budget will not allow for this build, this winter, but probably next winter.
Here´s an example I found google the net, but with very short runner length.
http://www.williamsenginedesign.com/_/rs...8&width=428
Tom
