Re: Whats The Go Fast Electric Fan [Re: Sport440] #908043
01/18/11 08:27 PM
01/18/11 08:27 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
30-13 was correct for hhr fan.Taurus fan i didn't measure myself was told that by someone else.I couldn't fit the Taurus fan on my can so i didn't measure it myself .But since this i have switched to a different fan.
Re: Whats The Go Fast Electric Fan [Re: gtx69] #908044
01/18/11 09:08 PM
01/18/11 09:08 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Taurus fan pull more amps than hhr fan.,It is also thicker.I know you will need a lot of alternator for the taurus fan.Check the amps for the taurus.
I run the Taurus fan...and it's a great fan. But he's right...it pulls way more amps both at startup and while running. No telling if it actually pulls more air (the 4000cfm) like people claim though. I run a 140 amp powermaster alt...so it doesn't bother me.
The Taurus fan may be thicker...but it likely can fit where the HHR won't because its motor is offset in the shroud allowing the waterpump pulley to clear the fan in my car. The HHR wont fit my car with a mech water pump...but it would clear with an electric Water pump.
I would run the HHR fan if I could just because it would fit my northern radiator almost perfectly.
Re: Whats The Go Fast Electric Fan [Re: gtx69] #908045
01/18/11 09:15 PM
01/18/11 09:15 PM
MR_P_BODY Offline OP
Being that the Taurus fan assm is thicker(the whole
thing) I probably cant use that... I'm working with
some small area for the radiator and fan
Re: Whats The Go Fast Electric Fan [Re: MR_P_BODY] #908046
01/18/11 09:59 PM
01/18/11 09:59 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
MR P BODY how much room do you have between waterpump nose and radiator? what size rad do you have?
Re: Whats The Go Fast Electric Fan [Re: gtx69] #908047
01/18/11 10:06 PM
01/18/11 10:06 PM
Well thats the problem... I have to put the radiator
in the nose/fascia on a angle... so its not the fan
motor itself I have to clear... it'll be the shroud
more than anything(at least I hope)
EDIT
I'm trying to get a 18" X 24" radiator in it
Re: Whats The Go Fast Electric Fan [Re: Sport440] #908048
01/18/11 10:25 PM
01/18/11 10:25 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
depends on the size of your rad the HHR fan was to small for my rad so I found 1 from a 95 caravan that works great and covered my entire rad.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Whats The Go Fast Electric Fan [Re: MR_P_BODY] #908049
01/18/11 10:35 PM
01/18/11 10:35 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Gotcha now.Brainstormer.Sleep on it.Any pictures of the space?
Re: Whats The Go Fast Electric Fan [Re: sunroofgtx] #908050
01/18/11 10:54 PM
01/18/11 10:54 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Sweet. I missed out on a member selling his. Eric, is it as cheap to go through you? Maybe I'll call Rock Auto and use the discount code.
Rick...I'm not at a GM store anymore....Rock Auto would be the way to go. They show three different manufacturers for the HHR fan...personally I would probably drop the extra $9 for the Dorman..
2006 CHEVROLET HHR LS 2.2L 2189cc 134cid L4 FI (D) DOHC : Cooling System : Radiator Fan Assembly Wiki Price
TYC Part # 621450 {#15817306, GM3115200}
Assembly; RADIATOR & COND
- Stocked in outlying warehouse--shipping delayed up to 1 business day
$50.79
Add to Cart
VARIOUS MFR Part # GM3115200 {#15817306}
w/2.2L/2.4L engine; Radiator cooling fan assy
$55.79
Add to Cart
DORMAN Part # 620951
Fully Assembled for Ease of Installation; w/AC; Incl. Shroud, Motor & Blade
$59.79
Add to Cart
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Whats The Go Fast Electric Fan [Re: Eric] #908051
01/18/11 10:58 PM
01/18/11 10:58 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Mike i am running the toures fan on my big block dart and i thought it fit better on my car better than the hhr one did. i am running it on the high setting and am only useing a 35 amp fuse.its has been run like this for over a year and has not blown the fuse yet. i got it shiped on ebay with a life time warrent with plug for 110.thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Whats The Go Fast Electric Fan [Re: BBR] #908052
01/18/11 10:59 PM
01/18/11 10:59 PM
And lucky for you I just got a RockAuto discount code in my email:
27638392284705
I think it's 5%, but hey, it's better than nothing!
Well I just ordered the HHR fan and used that 5%
discount.... thanks
Re: Whats The Go Fast Electric Fan [Re: MR_P_BODY] #908053
01/18/11 11:15 PM
01/18/11 11:15 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
27638392284705
discount.... thanks
Oh snap....in the time it took me to send you a PM... ...Still a good deal Mike....I'll send the same to Rick...
