Re: Opinions for best no puke oil evac tank...
[Re: Cab_Burge]
#907948
01/19/11 07:35 PM
01/19/11 07:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I like that moroso tank, mine is quite a bit shoter. Ive been battling this problem since i put my pump on, so keep up the suggestions.
How about installing a drain hose ffrom the catch tank back into the motor, a gravity feed design with a real light one way check valve, say three or four pounds of vacume like a PVC valve or something like that
I shoot for about 12" of vac so if you had a valve that would open at 4" you would basically have a vac leak coming in via the puke tank
[Re: MR_P_BODY]
#907949
01/19/11 07:52 PM
01/19/11 07:52 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I pull my vacuum right bank(even side 2,4,6,8)of the valve cover. Notice where I have my pop off valve. That ended my problems with it blowing a fine mist of oil out the filter on the tank.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: HEMIFRED]
#907952
01/19/11 10:41 PM
01/19/11 10:41 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
some here have filled the tank with stainless steel Brillo type material to stop the spray.
That sounds like a good idea...
