Mopar 340 max rpm?
#90593
07/19/08 03:08 AM
07/19/08 03:08 AM
It's basically all in the title. What is the max RPM of a stock 340? What is it's redline?
Re: Mopar 340 max rpm?
#90595
07/19/08 10:18 AM
07/19/08 10:18 AM
Posts: 4,463 Rome, PA
Ryan_340
Rome, PA
I wouldn't turn a stock one much over 6,000 myself.
1972 Power Wagon W100
1973 Power Wagon W200
1971 Duster
1972 Dart Swinger
3-1972 Demons
[Re: MoparforLife]
#90597
07/19/08 10:29 AM
07/19/08 10:29 AM
Posts: 1,593 USA
VS29H0B
USA
+1
There is no point in revving any engine past it's power peak.
You won't get any more horsepower, and all you are likely to do is cause damage.
6,000 RPM is about all you should ask out of a stock 1968 - 71 340 with higher compression. Valve train float at any RPMs above peak mean great risk of serious internal engine damage.
Like the women I have dated --- Always looking for a better deal ....
#90598
07/19/08 11:24 AM
07/19/08 11:24 AM
The 73 Duster 340 I used to have (when it wasn't too far from new) was pretty well done at 5200 with the stock exhaust manifolds. Headers raised the shift point to 5800, everything else the same.
[Re: MoparforLife]
#90601
07/19/08 07:50 PM
07/19/08 07:50 PM
Posts: 1,481 Outside
thedriver
Outside
i used to run a pure stock 340 duster. the car would run its best times with the shifter left in drive...it shifted somewhere between 5600-5800. 6000rpm would be the tops i would go.
1973 challenger Dana. 4 speed. Low deck.
[Re: thedriver]
#90602
07/20/08 12:05 AM
07/20/08 12:05 AM
I read an article on the 340 and it said that because of the free flowing heads, it could rev up to like 8000. I was skeptical, and I guess I was right. That seemed pretty high.
Thanks Everyone
#90603
07/20/08 01:23 AM
07/20/08 01:23 AM
RapidRobert
Mauisnow13 if you are up for alot of reading(online of course) on this subject you might go to www.moparchat.com & scroll down to & click on circle track chat & read Sanborns oiling mods that are in a sticky at the top. Alot of SB high rpm oiling mods/prep.Excellent material but again a long read.
[Re: MoparforLife]
#90604
07/20/08 08:22 AM
07/20/08 08:22 AM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
He asked about STOCK - not modified.
The first test is a stock rebuild.
[Re: AdamR]
#90605
07/20/08 10:32 AM
07/20/08 10:32 AM
RapidRobert
this is an opportunity for me to put into practice my belief that argueing on these message boards is like wrestling with a greased pig, you can't win & sooner or later you figure out that the pig likes it DAMHIK.
