Re: 5 by 4-1/2 bolt pattern wheel?
[Re: MO_PA]
#903708
01/13/11 05:16 PM
01/13/11 05:16 PM
Posts: 616 TP Exit 7, NJ, USA
DANA60
TP Exit 7, NJ, USA
If I get your question, and maybe it's a trick one, but the answere is: ALL other then A body cars were 5 bolt with a 4 1/2 spacing. IMPERIAL, CHRYSLER, (PLYMOUTH, DODGE) B and E but not A bodies. Not sure about sure about later ones (F, K etc.) A's had a 4 inch spacing.
[Re: MoparforLife]
#903710
01/13/11 05:28 PM
01/13/11 05:28 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
So I looked it up... http://www.teufert.net/wheels/bolt-pat.htmChrysler/DeSoto - all full size RWD cars (exc. Imperial) '37-'89: 5 x 4 1/2 Imperial 54-66: 5 x 5 1/2 Imperial 67-71: 5 x 5 An exception missed on that webpage is the 81-83 Imp, which was 4 1/2. Don't see 72-76 listed.
[Re: DANA60]
#903711
01/13/11 05:30 PM
01/13/11 05:30 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Just for future reference everything except trucks and maybe imperials were 5x4.5 starting with 1973 ...
[Re: MO_PA]
#903715
01/13/11 08:08 PM
01/13/11 08:08 PM
Posts: 1,024 In the twisties
RokketRide
super gas
super gas
In the twisties
Come on now! Every wheel I measure is 4-1/4, not 4-1/2. (68 Coronet R/T, 64 Belvedere, 62 Fury, 74 Valiant, 88 Chrysler) Except the older A-Body wheels from a 68 Valiant. A friend needs 4-1/2 and I'm attempting to locate some wheels for him.
I thought I could measure a wheel But????
Have you been measuring like this:
http://www.summitracing.com/expertadvice...chartsandguides
[Re: MO_PA]
#903717
01/13/11 09:50 PM
01/13/11 09:50 PM
Posts: 173 Milano, Italia
FK5
Milano, Italia
Thanks OzHemi, and the rest of you who helped on this.
Today I learn how to measure a wheel.
So back to my search. The wheels I'm searching for measured 4-1/2 center to center. Does that make them 5"?
Would that be an Imperial wheel?
Why did you measure them center to center when the instructons say back of one lug to center of the other? You're better off going back and doing it right. That's better than having us guess.
What car is it for?
[Re: MO_PA]
#903718
01/13/11 10:17 PM
01/13/11 10:17 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Could be 5 on 4.75 or 5 on 5 I suppose depending on just what size the holes are, best is to measure it the right way as mentioned. Figure on a steel wheel the holes will be just over 1/2" in diameter, so it would be another 1/4" or so than what you measured. If it was an aluminum wheel made for shank wheel nuts the holes will be somewhat larger.
Measuring it from edge to center takes that into account already.
[Re: MO_PA]
#903719
01/13/11 10:19 PM
01/13/11 10:19 PM
DaytonaTurbo
Manitoba, Canada
So then they're most likely chevy bolt pattern. 4.75".
